Loading Tires???????????
/ Loading Tires??????????? #1
JimR
Elite Member
Central Ma.
Kioti NX4510HST
Has anyone ever loaded their own tires? What did you put in them Calcium, antifreeze, etc?????. Where did you get a pump to fill them or did you make one?
/ Loading Tires??????????? #2
Low temp WW fluid. The item to use comes from NAPA and screws on the valve stem. It let's you burp the air. About 7 bucks. There was a great thread on this a while back.
Thanks for the info. I'll be heading there today. I guess it will take many many gallons to fill the tires up.
/ Loading Tires??????????? #4
well, lets see if I can figure out how to give you this link I got from someone else here.
tires
Yeah, I think that worked
Mike
/ Loading Tires??????????? #7
I have a real problem with using windshield washer fluid. That stuff costs nearly a buck a gallon!
Why not fill with plain water and add a gallon of alcohol per tire?
/ Loading Tires??????????? #8
Hi
I am thinking about using used hydraulic and used motor oil to load my tires, what do you folks think? wont have to worry about rust
Charlie
/ Loading Tires??????????? #9
I don't know that I would do that. Some oils have additives that destroys certain rubbers.
/ Loading Tires??????????? #10
</font><font color="blue" class="small">( Hi
)</font>
Oil is lighter than water.
Mike
/ Loading Tires??????????? #11
Not to mention the environmental issue if there's a leak. Yeah, the ww fluid is a buck a G., but the difference is cost isn't that way off. I had an incident with a chloride tire once. Don't want to go through that again. Anti-freeze is not very environmental either. Including the low-tox stuff. I preferred something that would give a fair amount of weight and be as 'friendly' as possible should a leak occur. I've heard a lot about the foam filled tires. I was thinking of doing an experiment with the low expanding canned foam on a junk tier to see how that works. I'm stressin' already from the frequent flats. Always finding the hidden barbed wire in the 'lawn'......
3 Point Hay Forks (A62613)
3 Point Hay Forks...
CASE TV450B SKID STEER (A65053)
CASE TV450B SKID...
FORD 2810 TRACTOR (A64277)
FORD 2810 TRACTOR...
Frontier QA Pallet Forks (A64126)
Frontier QA Pallet...
2015 Ford F-250 Pickup Truck (A61567)
2015 Ford F-250...
2016 Deere 550K LGP (A64126)
2016 Deere 550K...
