Loading tires with Propylene Glycol
   / Loading tires with Propylene Glycol #51
Have you never seen a used tractor advertized wherein the owner points out that the rear rims were rusted out due to them being loaded with CaCl? You've got to be kidding. I've seen plenty. Just check out any of the used tractor forums, Yesterday's tractors, etc. Don't know about WWF.
I don't know the ingredients in RimGuard but the name itself suggests that it has a corrosion inhibitor package like any coolant system antifreeze does. That would protect against the corrosive effects of oxygen in the compressed air and the dissolved oxygen in the water. So, I remain unconvinced by your so-called "pretty convincing evidence."
   / Loading tires with Propylene Glycol #52
I specifically mentioned that CaCl can rust (duh!;) ). However, it tends to be only when there is extra oxygen made available such as when the tire/wheel is broken down or when there are undetected leaks around the valve stem. Of course there can be rust that develops over 15-20 years which effectively destroys the wheel but the big companies simply advise that one carefully washes off the rims whenever they are broken down. The main point being that rust occurs VERY slowly when the only oxygen available is that contained in a normally sealed inflated tire. Don't you think farmers with thousand dollar wheels on their big tractors would be using nitrogen instead of compressed air if it had been shown to be important in preventing rust? I haven't found a word on the subject of nitrogen in tractor tires from the big companies like Goodyear. And, as far as I can tell this thread is the only time on TBN that the issue of nitrogen has come up. My point is just to point out that some theoretical NASCAR advantage does not translate into practical evidence based in tractors. Even filling even passenger car tires with nitrogen is a silly marketing gimick used by tire retailers to upcharge. It has limited but more rationale for passenger cars than it does for farm tractors though. Try Googling on this subject. It is pretty clearly a marketing fad and there is no reason to contaminate TBN with that crap (excuse me Bird, I meant crud:D ).
   / Loading tires with Propylene Glycol #53
Island T the technical term is Manure.. Something most of us are familiar with:p
   / Loading tires with Propylene Glycol #54
Point taken.:D
   / Loading tires with Propylene Glycol #55
IslandTractor said:
. But to fill tractor tires....please, give me evidence to support the suggestion.
Why give evidence... why can't some one just -want- to do it.
If, in your own words, you can understand why nascar does it.. then why does that not also satisfy someone else wanting to do it? IE.. if nascar does it for superior temperature stability.. then why couldn't a tractor user with a few extra bucks burning a hole in his pocket also use it for a lil more pressure/temperature stability?
If your argument is that it's fine for nascar.. but not fine for everyone else.. well then.. you need to run for office as you are advocating a double standard ;)
I'll admit a nitrogen charge in a tractor tire is likely to have only trivial effects .. but isn't that what life is about ( at least here in the USA anyway).. the ability to make trivil choices about what one does with ones life and stuff.. as long as it doesn't hurt anybody else... right? Now.. if you disagrre with that.. you DEFFINATELY need to run for office.. but watch out.. hillary and obama are already taking the top spot in the party you'd be joining.
Ok mods.. I really really tried to keep that one nicey nicey... and essentially non political.. save for a few proper names..
edit: I'd like to add that I'm not advocating nitrogen charging.. just the ability to freely make the choice .. and if the choice was made.. that it would not be to reduce the O2 content for the purpose of staving off corrosion.. but for mere pressure stability. The corrosion issue can be adequately handles by cleanliness and proper maintenance... besides.. I've never seen a inner-tube rust!
soundguy
   / Loading tires with Propylene Glycol #56
soundguy
No problem. Free country etc etc. I ain't no pinko commie, I just don't vote for idiots like Bush. And, to get back on subject, I am simply pointing out that there is no evidence that nitrogen in this context is useful. It doesn't make sense except as a wahoo gotta-have-the-latest NASCAR-stuff-on-my tractor gimmick. Tractor tires don't overhead and burst into flames. Most importantly however, there is no data to support the practice in tractor tires. I don't give a flying hoot if some gullible person decides to muscle his tires down to the local tire shop and have them filled with nitrogen. I just want to challenge TBNers who support the idea to come up with some data or a rational engineering argument before suggesting it makes sense. For those interested in pissing away money on a gimmick I have no argument. I'd rather piss away my extra money on beer.
   / Loading tires with Propylene Glycol #57
Ok.. here's the rational engineering argument.
Nitrogen is more volume stable in a wide range of temperatures vs plain old mixed air. Thus when you have a tire that goes from cold to hot, with mixed air, with a more or less fixed internal volume, then the pressure changes a little bit. Compair that to a tire with. say.. the nitrogen charge which is more likely to have a constant pressure inthe hot to cold range.
there's your ancedotal rational argument. I never claime dit would be anything more than a trivial difference... but a difference it is.
soundguy
   / Loading tires with Propylene Glycol #58
soundguy
OK, I can accept both the argument and the assessment that it would be a trivial difference. Peace. I'm now going to add a trivial amount of nitrogen to my tires and then slap a bunch of NASCAR stickers on it.:)
   / Loading tires with Propylene Glycol #59
speaking of arguments. I never could understand why someone would spend a lot of money on beer just to urinate it out. I think I would be happier spending my money on something like nitrogen so that I could have constant pressure in my tractor tires and maybe get a trifle beter fuel mileage. Rather than spend it on something that is just going to filter through some internal organs and end up either on or in the ground.
   / Loading tires with Propylene Glycol #60
Good kidney exercise. Cheaper than a health club.
2004 Ford F-250 Liftmoore 2,700 LB 1 Ton Crane Service Truck (A53422)
2004 Ford F-250...
2008 CATERPILLAR 725 OFF ROAD WATER TRUCK (A51406)
2008 CATERPILLAR...
2009 Mariah SC23 23ft. Cabin Cruiser with T/A Boat Trailer (A55853)
2009 Mariah SC23...
2007 Honda CR-V SUV (A53424)
2007 Honda CR-V...
2008 Ford F-250 Crew Cab Pickup Truck (A55852)
2008 Ford F-250...
