loading tires ck3510hs
/ loading tires ck3510hs
I checked my manuel it says for industrial tires my size 45psi front and 41 psi rear.
/ loading tires ck3510hs #23
That sounds like a LOT. My DK45S manual says 20 PSI front and back. In any case, never exceed the max on the sides of the tires.
/ loading tires ck3510hs #24
The reason I run the max recommendation on the fronts is I mostly do loader work and often carry as much as the loader can lift.
/ loading tires ck3510hs #25
I run 40 PSI in the front and 15 PSI in the rear. R-4's on a DK 35.
Land Survey Kit (A60463)
Land Survey Kit...
2024 Linx UT3577121G (A60463)
2024 Linx...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Giyi DHC Mini Quick Attach Forks (A60463)
Giyi DHC Mini...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
2016 Doyle 10T Tender (A56435)
2016 Doyle 10T...
