loading tires ck3510hs
/ loading tires ck3510hs
I checked my manuel it says for industrial tires my size 45psi front and 41 psi rear.
/ loading tires ck3510hs #23
That sounds like a LOT. My DK45S manual says 20 PSI front and back. In any case, never exceed the max on the sides of the tires.
/ loading tires ck3510hs #24
The reason I run the max recommendation on the fronts is I mostly do loader work and often carry as much as the loader can lift.
/ loading tires ck3510hs #25
I run 40 PSI in the front and 15 PSI in the rear. R-4's on a DK 35.
2001 Volvo Sleeper Selling Offsite (A62613)
2001 Volvo Sleeper...
2017 Ford F-550 Altec AT37G 37ft. Insulated Bucket Truck (A64556)
2017 Ford F-550...
Duratech HD 8 Tub Grinder (A62613)
Duratech HD 8 Tub...
2011 GALYEAN 130BBL (A65643)
2011 GALYEAN...
2022 EZ-GO ELITE...
2019 KENWORTH T680 T/A 6X4 SLEEPER TRUCK TRACTOR (A59910)
2019 KENWORTH T680...
