Loading logs
/ Loading logs #1
czechsonofagun
Elite Member
Old Dominion
Kubota B1750
I have few nice maple logs on the ground I would like to get to the sawmill. About 15" diameter, 12 feet long. My trailer would handle the load, my problem is how to get it up.
I dont have a front loader, the tractor is only 20hp Kubota, I dont think the 3pt would be up to it.
My plan as of now is to build simple gantry and hang a hoist from it, lift one end of the log, backup the trailer under and lower the log.
Opinions? Ideas?
Thanks
Prokop
/ Loading logs #2
Can you put a floor jack under the log about 4' in from the end? You would have to dig out an area to slip the jack underneath and put a 2x8 scrap under it for stability. If you could jack the log up 10" at that point, the end would raise 15" Would that be enough to slide it onto the trailer you have?
I think you are underestimating your tractor. Attach the 3pt approx 4' from the end like the above suggestion. All you need to do is lift the log straight up 10-15" off the ground at that point to get 15-20" elevation at the log end. You then back the trailer under the high end. You are not lifting the entire log's weight. Most of the weight is still dead weight resting on the ground. With the tractor at a 90 degree angle to the log 4' in from the end, you can still get the trailer close enough to load the end.
Nothing to build. All you need is some chain.
/ Loading logs #3
If your trailer is flat (no rails), load from the side. Lay two or three 2x6 or such against the trailer, roll the log to the bottom of the boards, while getting a sturdy rope or chain around it. Hook to your tractor on the other side of the trailer and slide/pull them up the 2x6s...nail a 4x4 or such to the trailer floor to keep them from rolling across and off the other side.
/ Loading logs #5
I have a Kubota L175 ( about 17 horse ) and have used the boom pole with pretty good luck. You may need to lift just one end of the log and swing it on to the trailer, then do the other. I've moved some logs that way when the tractor would not lift the whole thing. Also, you may need to hook the chain part way up the boom pole- less leverage,but you won't left the front end of the tractor, and you can left more weight that way. good luck, and watch your hands!
In my pre tractor days I would make a ramp up to the side of my trailer with 4x4's and roll them up. A come-along may work, but sometimes the trailer would move instead of the log! Cant hook and muscle seemed the best. Gotta watch the log doesn't roll back on you.
/ Loading logs
LMTC the trailer is a box, end gates are hinged on the bottom, I have to slide it in from the back.
Goaliedad thanks for the shared experience. If I take baby steps I am sure I will get it done.
/ Loading logs #8
Works great especially if you fasten one end of the chain to the trailer, run it under and then back over the log to the other side of the trailer. When you pull, it rolls the log up the ramp. That was one of the techniques used back in the pioneer days.
Harry K
/ Loading logs #9
Set your vehicles up like this. Use tractor to pull log up onto round fence post, then pipe, then barrel. It should roll right up into trailer. Might put pipe in bed of trailer to allow to roll easily to front.
  • Old technology.pdf
/ Loading logs
Interesting, thanks. I will definitely give it a try - as soon as the log unfreezes from the ground.
I had also this vision of 2" hitch in the front bumper, hook up the trailer to it and get an off road winch on the front bumper. Similar setup exists for flat bed tow trucks.
/ Loading logs #11
Given the access is only from the rear of the trailer, and the boom most likely will not pick up the whole log I would lift one end of the log onto the trailer, and place a pipe or small log under it, then pick up the other end of the log with the boom, and slowly back the log onto the trailer. Piece of cake! You could also use a come-along to pull the log in. Of course you have to make sure the tongue doesn't go up!
The first logs I loaded were on a similar trailer- no tractor, lots of "sure we can do this.." we unhooked the trailer from the tow vehicle, and used a comealong to pull the first log onto the trailer just enough to hold it, tongue up. Then two more logs were pulled in. We kept pulling one, then another until the trailer was just about balanced, Pulled the tongue down and pulled, pushed the logs in the rest of the way. Lots of work, and not real safe, but hey, it worked.
I now have an old boat trailer frame that makes a great log hauler- no sides help a bunch!
/ Loading logs #12
czechsonofagun said:
Chain I got, I am gonna buy Tractor Supply Company - BOOM POLE and give it a shot. It is much easier than building a graple.
Thanks
Just a word of caution, a 12foot log 15inches on small end is about115 board feet, and will weigh around 1200 LBS.
/ Loading logs #13
Er, uh, that trailer looks to be at most 8 feet long. Single axle trailer, heck any trailer, needs 10% or more tongue weight. 12 foot long log. I see a problem. Do you intend to cut the logs to fit within the trailer bed?
I have winched, with a come-a-long, my dead 4500 lb tractor up and into my car hauler trailer. It took a little while and I got thirsty but the experience tells me that a come-a-long will get this done for you.
/ Loading logs
You are right, the trailer is 8 feet, but I can load it all the way to the end of the tongue and it gives me 2.5 more feet. I moved long logs with this setup, just has to take it slow and easy.
But thanks for the warning, always good to bring the attention to safety.
/ Loading logs #15
2026 DEVELON DX27Z-7 EXCAVATOR (A65053)
2026 DEVELON...
2017 JOHN DEERE 85G MINI EXCAVATOR (A59914)
2017 JOHN DEERE...
2018 Kubota U35-4 (A64126)
2018 Kubota U35-4...
Skid Steer Smooth Drum Roller (A65640)
Skid Steer Smooth...
2000 International 4900 Tandem Truck (A66285)
2000 International...
Mini Skid Steer Mount Plate, 5/16" Thickness (A62679)
Mini Skid Steer...
