Loader Valve Test Port Location
/ Loader Valve Test Port Location
Thanks J_J,
I just talked with the dealer again about a replacement valve. This valve is no longer available. He also explained about the leaking spools being caused by scoring on the spool or housing not by seals/O-rings.
According to the info I have the system is 2125psi and 20gpm so I don't think the valves you listed have sufficient flow. The dealer said they have replacing these with a Cross joystick around $400-$450 from them.
In light of all this info, I will just use the valve as is until I muster enough time/money to go for the replacement. Who knows, there may be something else go wrong that turns the whole tractor into scrap.
I still plan to attach the PB fittings and build my auger and grapple. I will be able to use those on any other tractor as well. Nothing lost so far except a couple dollars worth of O-rings which I still have for other use.
Now we're talking!!
I like the three spool valve in particular. I may have to change course on my plans here. I need the auger, but what I really need is holes, in the ground that is.
So, for now, short term, I may just rent a skid loader w/auger , drill my holes, and hope I have enough left from the money I was going to spend on an auger to buy the 3 spool joystick. Once I have it, I can begin fabricating mounts and plumbing to install it while still using the tractor as is.
Once I have installed the new valve, I can start working more towards installing my grapple and auger plumbing.
Yep, that works for me!
Thanks!!
2017 Bobcat E55 (A60462)
2017 Bobcat E55...
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2015 Caterpillar 430F 4x4 Extendahoe Loader Backhoe (A60352)
2015 Caterpillar...
2007 FORD EXPEDITION XLT (A62130)
2007 FORD...
2025 80in. Hydraulic Dual Cylinder Root Grapple Skid Steer Attachment (A61567)
2025 80in...
