Loader valve problems
/ Loader valve problems #1
hazer36
Started a new post to see if I could get more help on loader valve.I have had this thing apart twice,replaced all orings,and still no go.Someone had been in it before and I don't think the release valve is in properly.
If anyone knows sequence of parts in it,I would appreciate the help.
By the way it is the old style valve.
Finally got the loader working after going thru valve three times.I was right about pressure release valve,the previous tinkerer left part of it out.I discovered it after reading post on ctoa site.Had to make it using bench grinder.It is the part that goes on bottom of lower spring,without it you couldn't get spring tight enough.Also they had put part of valve upside down.
Then after got it all hooked back on tractor I noticed they had hoses crossed,one raise/lower hose on tilt spool and vise versa. So with the low pressure setting due to the messing part, the crossed hoses would kick it out.Reason pump seal was blown to.
It works well now.All I need to do now is check pressure with a gauge.
/ Loader valve problems #3
Excellent find! It is always hard to follow into some one elses work and even harder if they didnt know what they were doing and lost parts. Great way to break it down and get each problem resolved
SKIDED FUEL TANK (A67714)
SKIDED FUEL TANK...
2021 JCB 300T SKID STEER (A65056)
2021 JCB 300T SKID...
2012 JACK CO 130BBL VACUUM TRAILER (A67714)
2012 JACK CO...
2009 IHI IC70-2 CRAWLER CARRIER (A65056)
2009 IHI IC70-2...
GENERAC MOBILE PRODUCTS MLT6S LIGHT PLANT (A68842)
GENERAC MOBILE...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
