Loader valve problems
/ Loader valve problems #1
hazer36
Bronze Member
Started a new post to see if I could get more help on loader valve.I have had this thing apart twice,replaced all orings,and still no go.Someone had been in it before and I don't think the release valve is in properly.
If anyone knows sequence of parts in it,I would appreciate the help.
By the way it is the old style valve.
Finally got the loader working after going thru valve three times.I was right about pressure release valve,the previous tinkerer left part of it out.I discovered it after reading post on ctoa site.Had to make it using bench grinder.It is the part that goes on bottom of lower spring,without it you couldn't get spring tight enough.Also they had put part of valve upside down.
Then after got it all hooked back on tractor I noticed they had hoses crossed,one raise/lower hose on tilt spool and vise versa. So with the low pressure setting due to the messing part, the crossed hoses would kick it out.Reason pump seal was blown to.
It works well now.All I need to do now is check pressure with a gauge.
/ Loader valve problems #3
Excellent find! It is always hard to follow into some one elses work and even harder if they didnt know what they were doing and lost parts. Great way to break it down and get each problem resolved
2016 Mobility Ventures MV-1 Passenger Van (A66736)
2016 Mobility...
2013 KUBOTA SVL 90-2 SKID STEER (A65056)
2013 KUBOTA SVL...
2019 CATERPILLAR 315FL CR EXCAVATOR (A65056)
2019 CATERPILLAR...
2004 Cadillac Eagle Ultimate Hearse, Eagle Coachbuilders, Hearse Collector Special (A63689)
2004 Cadillac...
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
PORTA POTTY (A67714)
