loader valve not working
/ loader valve not working #1
coldstiffy
north dakota
newholland 1620
Hi need help with new Holland 1620 I added a factory loader valve spool and it works but only when the 3point is getting lifted otherwise the loader will not work I cant figure the problem out the kit has all hard lines so they only fit one way need advice
/ loader valve not working #2
On my non-New Holland tractor there is a requirement to insert a blind-plug inside the divider block where the aux (front-end loader loader) valve line connects to the tractor so all works correct with the aux valve added. You might look for similar instructions in the workshop manual for your New Holland (it's an easy-to-miss detail in my Yanmar WSM).
2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK (A66091)
2018 MACK LR633...
2010 Freightliner M2 106 Pac-Mac KBF 20H Forestry Grapple Truck (A66736)
2010 Freightliner...
JOHN DEERE 5100 TRACTOR (A63291)
JOHN DEERE 5100...
2008 FORD CROWN VICTORIA  CAR (A66091)
2008 FORD CROWN...
Vortex Walk-Behind Paint Sprayer (A64553)
Vortex Walk-Behind...
2001 Freightliner FL112 T/A 5 Car Hauler Truck (A68183)
2001 Freightliner...
