Loader valve not droping the bucket.
   / Loader valve not droping the bucket. #1
aroostookboy
I've got a 2001 Kubota L4310, the problem I've got is when I want to lower the loader, the lever won't push into the lower position. It use to pop into the drop position, but now it won't go in at all. I've never got into a valve body and not sure if I can. Does anybody have a idea what is going on, and a fix if possible. Thanks Bruce.
   / Loader valve not droping the bucket. #2
Is the spool direct acting or cable activated?
Remove the cans and inspect the springs and little balls.
You may have some loose parts in the cans on the bottom, or some debris in the spool jamming it.
Check those QD. Unplug and reset.
direct, with Power be-on by pass. I thought it was the linkage but it defiantly internal.
   / Loader valve not droping the bucket. #4
Try removing the "cup" on the rear of the valve, it houses the detent balls for the float function, its probably corroded in there so you'll need to clean it up and pack with a light grease. Be careful not to loose the balls when opening it!
2012 Dodge Ram 1500 Tradesman Crew Cab Pickup Truck (A55788)
2012 Dodge Ram...
UNUSED LANDHONOR AD-12-23C HYD AUGER (A54757)
UNUSED LANDHONOR...
UNUSED FOLDING WAGON (A54757)
UNUSED FOLDING...
2021 CATERPILLAR D4 LGP CRAWLER DOZER (A51246)
2021 CATERPILLAR...
2016 Nissan Frontier Ext. Cab Pick-up (A55788)
2016 Nissan...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A55787)
2025 Kivel 48in...
