loader tractor valve
/ loader tractor valve #1
jgrieve
I was hoping to put a cessna valve from a John Deere loader onto a ford 3000 tractor. the john deer valve is alot smaller than the one off the Ford. Smaller inlet and outlet and spools. im guessing that wouldnt work ? what I want to do is put on a valve that would have down pressure on the lift arms. the one that came on the loader did not. Have changed the lift arm rams need a different valve.
/ loader tractor valve #2
Most 3pt lift arms do not have down pressure.
Did you add some external cyl to provide down pressure ?
As far as a valve, you need to match the flow rate in GPM to the valve flow capacity.
not 3pt fel origionally had one way rams
/ loader tractor valve #4
I was hoping to put a cessna valve from a John Deere loader onto a ford 3000 tractor. the john deer valve is alot smaller than the one off the Ford. S.
Utilizing a JD hyd control valve on a Ford would be determined by what model JD the valve came from. A lot of JD's are closed center which ""will not work on a Ford"" unless it was the type that was convertible from closed to open(vice-verse).
/ loader tractor valve #5
Can you show picture of your setup?
2016 JOHN DEERE 7210R TRACTOR (A65054)
2016 JOHN DEERE...
1998 International 4700 Flatbed Dump (A62613)
1998 International...
Stout Utility Grapple XHD84 (A66285)
Stout Utility...
New/Unused Quick Attach Pallet Forks (A65583)
New/Unused Quick...
CONEX BOX (A65643)
CONEX BOX (A65643)
Titan Attachments Forks (A64126)
Titan Attachments...
