loader tractor valve
   / loader tractor valve #1
jgrieve
Bronze Member
I was hoping to put a cessna valve from a John Deere loader onto a ford 3000 tractor. the john deer valve is alot smaller than the one off the Ford. Smaller inlet and outlet and spools. im guessing that wouldnt work ? what I want to do is put on a valve that would have down pressure on the lift arms. the one that came on the loader did not. Have changed the lift arm rams need a different valve.
   / loader tractor valve #2
Most 3pt lift arms do not have down pressure.
Did you add some external cyl to provide down pressure ?
As far as a valve, you need to match the flow rate in GPM to the valve flow capacity.
not 3pt fel origionally had one way rams
   / loader tractor valve #4
I was hoping to put a cessna valve from a John Deere loader onto a ford 3000 tractor. the john deer valve is alot smaller than the one off the Ford. S.
Utilizing a JD hyd control valve on a Ford would be determined by what model JD the valve came from. A lot of JD's are closed center which ""will not work on a Ford"" unless it was the type that was convertible from closed to open(vice-verse).
   / loader tractor valve #5
Can you show picture of your setup?
2010 TROXELL 140BBL TRI AXLE VACUUM TRAILER (A50854)
2010 TROXELL...
2018 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
Mk Diamond MK-101 Wet Tile Saw (A49461)
Mk Diamond MK-101...
2005 OVERLAND TANK KILL TRAILER (A50854)
2005 OVERLAND TANK...
2018 Bobcat T590 Two Speed Compact Track Loader Skid Steer (A50322)
2018 Bobcat T590...
