Loader specs
/ Loader specs #1
Torvy
Super Member
North East Texas
TYM T574H
So I am researching to buy my tractor and I came across some puzzling information regarding FEL. This is on the brochure for NH.
I expect to see 2 capacity figures, one for at the pivot pin and one at the bucket (or thereabouts). What is puzzling me is that for a couple of the NH options the lift capacity is listed as greater 500mm forward. That's backward from everything else I have seen, including other NH FEL. The only difference I see is that the 2 models are mechanically self-levelling. 616TL and 626TL.
So is this a mistake, or is there something about MSL that changes things?
/ Loader specs #3
Mechanical self leveling feeds gravitational energy from the uncurling bucket back through the linkage and thus aids the arm lift to some extent.
/ Loader specs #4
Maybe you’re mixing up breakout force with lift capacity? Or maybe you’re mixing up a 500 mm high lift vs a full height lift?
/ Loader specs
I cannot find the specs that I found this morning...almost as if NH read my post and changed the brochure online...the 616 and 626 are not even showing now.
/ Loader specs #6
