Loader question
/ Loader question #1
robert23239
Does anyone know if the deere 52 loader will fit the 955 tractor ??
Also how much do you have to worry about blue smoke coming out of the exhaust during throttle up??
Robert
/ Loader question #2
I don't know about the loader. The blue smoke, depends on how much. Just check the oil level until you get a idea on how much it uses. I check mine every other time I use the tractor and if I can't remember I check it. Your tractor may just have some blow by until it reaches operating temp.
/ Loader question #3
I believe the 955 matches up with the 70A loader.
Blue smoke is generally not a positive thing you want to see with any engine (unless it's a 2-stroke). You might have ring wear or worn valve guides. If you note increased oil consumption - do a compression check.
That said; engines will run for many hours with either or both conditions - but not peak performance.
AKfish
2007 CRYOGENIC VESSEL NITROGEN TRANSPORT TRAILER (A67714)
2007 CRYOGENIC...
Unused 2023 Maybridge M79 3 Point Hitch Carrier Chain Harrow Lift Tractor Attachment (A66734)
Unused 2023...
2010 Chevrolet Silverado 1500 4x4 Ext. Cab Pickup Truck (A66736)
2010 Chevrolet...
3ft 5-Pointed Star Metal Decorative Sign (A66738)
3ft 5-Pointed Star...
110 GAL WATER TANK (A68842)
110 GAL WATER TANK...
2013 FORD F-150 (INOPERABLE) (A67714)
2013 FORD F-150...
