Loader problems..'powered down' stops working
/ Loader problems..'powered down' stops working #1
Sniggle
Jefferson County, WV
2003 Kubota B7800 (new to me @ 435 hours
My loader has been having a repeating (but infrequent) problem....the loader joystick will occasionally fail to activate 'bucket down' function. I will be able to push the joystick forward to activate float, but will not be able to find 'powered down'. This has happened 3 times, and each time 'powered down' returns in a minute or 2.
Any ideas on what is causing this...how to fix?
Thanks
/ Loader problems..'powered down' stops working #2
Yep..happened to me and I figured it out quick.
Bet you were using your 3PH at the time.
The 3PH lever for up and down doesn't automatically go back to center, it's easy to leave it in the full up or full down position. When you do.....you get the exact problem you describe.
Always make sure your 3PH lever is in the middle after you have raised or lowered it and your loader should be fine.
/ Loader problems..'powered down' stops working #3
Same thing here with the 3PH lever. I got my scare while plowing snow last winter. Use a rear blade in reverse and the FEL in forward. When the "problem" repeated itself several times I had a few choice words slip out before I discovered the cause was me.
2017 Chevrolet Silverado 1500 Pickup Truck (A64194)
2017 Chevrolet...
YANMAR VIO35-6A EXCAVATOR (A64279)
YANMAR VIO35-6A...
2015 Ford Taurus AWD Sedan (A64557)
2015 Ford Taurus...
2010 Mac Trailers Walking Floor Trailer (A64556)
2010 Mac Trailers...
2019 BOBCAT T595 SKID STEER (A65053)
2019 BOBCAT T595...
10FT S/A Utility Trailer (A64557)
10FT S/A Utility...
