Loader Pressure Release
/ Loader Pressure Release #1
aeblank
Cadillac, MI
Kubota L3940
So in this thread (http://www.tractorbynet.com/forums/...face-hyd-coupling-pressure-3.html#post4108995) we were discussing how QD fittings can be hard/impossible to re-attach after some amount of time. Temperature changes, settling, etc. can cause pressure to be behind the fitting.
I created a manifold (got my parts from KennyD!) to equalize and, if needed, vent pressure when I go to reattach the picture. It's slow moving....I bought the parts months ago. I assembled it recently. I'll attach it in a month or two. I'll know if it worked about April. HOWEVER, here it is......
/ Loader Pressure Release #2
I drop my three point down all the way and move my loader joy stick in all directions with the engine off. Been working for me for many years now.
I do that too. I *always* get some sort of pressure in the loader by the time I need to put it back on. No point in quick disconnects if I have to use a wrench to remove them to get rid of whatever (STUPID) residual pressure there is. I don't know if it's the loader settling or temperature swings, or what. All I know is that it's a problem.
Finally put the blower on, which means I took the loader off.
/ Loader Pressure Release #5
If you want to connect under pressure, then get the QD's that allow that.
If not, you have to make a dummy connector that relieves the pressure on the implement.
Sometimes the weight of the attachment will generate the pressure, and at other times the temp is a the problem.
It's not that I *want* to. I try to get rid of all pressure (tractor off) and let the loader settle. I still have huge difficulties putting it back on, wrasslin' with the connectors every single friggin time. Temperature, I can't control, not to mention I don't want to be a slave to when I "can and can't" remove my loader.
above is my dummy connector(s), with venting valve.
On my grapple, I connect the two sides together when I disconnect it. That keeps the connectors clean, and seems to eliminate any re-connection issues. I expect this manifold to perform the same function on my loader. I hope.
/ Loader Pressure Release #7
I like it!!! How much $ are you in to it?:thumbsup:
I can't remember!
I also bought a spare set of QDs to have on hand for the loader (they aren't the "ag" type that the local farm store would have).
Seems like maybe $35. In tractor-money, almost nothing.
Woulda loved something like this, but they're only 3-up, and I needed 4.
/ Loader Pressure Release #10
It was about $40 spent with us (4 x $6.50, 3/8" Male 7241B QD's) and then about $10 for the fittings. The valve was not sourced through us.
Valve was like $3 at Harbor Freight. So, $50-$55, I guess. Kinda high, but every time it (hopefully) saves me 20 minutes of insane frustration, the cost will go down. What's my hourly rate, maybe $50/hr? As an engineer, I could well be $150/hr. As a laborer that I often am at home, I'm what, $15/hr?....
We'll see!
/ Loader Pressure Release #12
I just take a block of wood and strike the end of the male coupling, a little oil will squirt out and then it will connect. I havent damaged a coupling "yet", but I wouldnt want to use a hammer to strike the coupling with. I havent noticed pressure being a problem with the female end of a coupling.
/ Loader Pressure Release #13
Yes...but on the Kubota's the male fitting is on the tractor side-the females are on the loader hoses.
SUPER happy to report that this manifold worked GREAT.
Last weekend it was warm, so I pulled the snowblower off.
Before mounting the loader, I lifted the hoses up, so they were the highest point.
I opened the valve and did hear a little pressure escape.
The connectors plugged into the tractor WITHOUT ANY STRUGGLE.
There was no breaking fittings loose, hitting pins with hammers/drift, no swear words, nothing.
/ Loader Pressure Release #15
:thumbsup:
Thanks for the update.
It was only a year in the making......
JOHN DEERE 5403 TRACTOR (A64280)
JOHN DEERE 5403...
2013 Chevrolet  Express 2500 (A62613)
2013 Chevrolet...
John Deere 4440 (A64119)
John Deere 4440...
John Deere 4955 (A64119)
John Deere 4955...
UNUSED IRLMC DELUXE MASSAGE CHAIR (A64281)
UNUSED IRLMC...
2019 INTERNATIONAL LT625 T/A 6X4 SLEEPER TRUCK TRACTOR (A59912)
2019 INTERNATIONAL...
