Loader Pressure Release
/ Loader Pressure Release #1
aeblank
Cadillac, MI
Kubota L3940
So in this thread (http://www.tractorbynet.com/forums/...face-hyd-coupling-pressure-3.html#post4108995) we were discussing how QD fittings can be hard/impossible to re-attach after some amount of time. Temperature changes, settling, etc. can cause pressure to be behind the fitting.
I created a manifold (got my parts from KennyD!) to equalize and, if needed, vent pressure when I go to reattach the picture. It's slow moving....I bought the parts months ago. I assembled it recently. I'll attach it in a month or two. I'll know if it worked about April. HOWEVER, here it is......
/ Loader Pressure Release #2
I drop my three point down all the way and move my loader joy stick in all directions with the engine off. Been working for me for many years now.
I do that too. I *always* get some sort of pressure in the loader by the time I need to put it back on. No point in quick disconnects if I have to use a wrench to remove them to get rid of whatever (STUPID) residual pressure there is. I don't know if it's the loader settling or temperature swings, or what. All I know is that it's a problem.
Finally put the blower on, which means I took the loader off.
/ Loader Pressure Release #5
If you want to connect under pressure, then get the QD's that allow that.
If not, you have to make a dummy connector that relieves the pressure on the implement.
Sometimes the weight of the attachment will generate the pressure, and at other times the temp is a the problem.
It's not that I *want* to. I try to get rid of all pressure (tractor off) and let the loader settle. I still have huge difficulties putting it back on, wrasslin' with the connectors every single friggin time. Temperature, I can't control, not to mention I don't want to be a slave to when I "can and can't" remove my loader.
above is my dummy connector(s), with venting valve.
On my grapple, I connect the two sides together when I disconnect it. That keeps the connectors clean, and seems to eliminate any re-connection issues. I expect this manifold to perform the same function on my loader. I hope.
/ Loader Pressure Release #7
I like it!!! How much $ are you in to it?:thumbsup:
I can't remember!
I also bought a spare set of QDs to have on hand for the loader (they aren't the "ag" type that the local farm store would have).
Seems like maybe $35. In tractor-money, almost nothing.
Woulda loved something like this, but they're only 3-up, and I needed 4.
/ Loader Pressure Release #10
It was about $40 spent with us (4 x $6.50, 3/8" Male 7241B QD's) and then about $10 for the fittings. The valve was not sourced through us.
Valve was like $3 at Harbor Freight. So, $50-$55, I guess. Kinda high, but every time it (hopefully) saves me 20 minutes of insane frustration, the cost will go down. What's my hourly rate, maybe $50/hr? As an engineer, I could well be $150/hr. As a laborer that I often am at home, I'm what, $15/hr?....
We'll see!
/ Loader Pressure Release #12
I just take a block of wood and strike the end of the male coupling, a little oil will squirt out and then it will connect. I havent damaged a coupling "yet", but I wouldnt want to use a hammer to strike the coupling with. I havent noticed pressure being a problem with the female end of a coupling.
/ Loader Pressure Release #13
Yes...but on the Kubota's the male fitting is on the tractor side-the females are on the loader hoses.
SUPER happy to report that this manifold worked GREAT.
Last weekend it was warm, so I pulled the snowblower off.
Before mounting the loader, I lifted the hoses up, so they were the highest point.
I opened the valve and did hear a little pressure escape.
The connectors plugged into the tractor WITHOUT ANY STRUGGLE.
There was no breaking fittings loose, hitting pins with hammers/drift, no swear words, nothing.
/ Loader Pressure Release #15
:thumbsup:
Thanks for the update.
It was only a year in the making......
2020 TIGERCAT 234B LOG LOADER (A64276)
2020 TIGERCAT 234B...
2011 Nissan Juke AWD SUV (A61574)
2011 Nissan Juke...
1996 International Water Truck with a Caterpillar Engine (A63688)
1996 International...
1836 (A64280)
1836 (A64280)
(50) UNUSED 3'x8' CORRUGATED METAL SHEETS (A64281)
(50) UNUSED 3'x8'...
UNUSED WOLVERINE HYD MINI STUMP GRAPPLE (A64281)
UNUSED WOLVERINE...
