Loader position
   / Loader position
Depending on the bucket/loader perhaps they can see a lot better with it in the air? That's all I've got other than what has already been said. Seems like a good way to really throw off the balance of the tractor.
That was what I thought but it seems awfully risky just to get a better view.
   / Loader position #12
You were taught the correct way! I think this is one of those things that people do without really thinking through...like driving around with the ROPS folded down just because they're on level ground, or aren't doing anything "dangerous"....just a bad idea.
IMHO it get back to the old saying: "monkey see-monkey do" for those operators that drive around with loader in the AIR!!!
   / Loader position #13
I have a neighbor that mows (15' bat wing) with a JD2550 MFWD and JD245 loader. He mows with the loader raised. Not as high as it will go, but high enough he is looking under it. I am thinking why doesn't he just remove loader when he mows?
   / Loader position
You should pop over and ask his theory behind operating that way vs removing or lowering the loader.
   / Loader position #15
The gentleman with the 2550 may not take it off, because he may be missing the park stands or have taken them off as they rattle some. The 245 loader looks a lot like my 540 loader. To take the loader of my 5210, you need to be on level ground (as the loader pushes the tractor off it) and not on wet ground (so the parking stands do not sink into the ground). It is a 16 step process to get it off and then you get to wrestle the 4 hoses, since they go from the loader to the back of the tractor. Then there is 13 steps to put it back on, starting with wrestling the hoses, than the masts do not always extend evenly so there is some playing around, to get them into the mounting frame.
If anyone is interested here is a link to the 540 operator manual.
http://manuals.deere.com/omview/OMW44993_19/
Went to take the loader off of my friends 6300 and not only is he missing the parking stands, the hoses or not quick disconnect and even if they were I think they would be too short.
A neighbor waits until the weeds get real high before using his bush hog and leaves the hay spear and at about 2 feet off the ground to knock the weeds over with the loader instead of with the tractor, which he has no grill guard on. I would also think this helps to keep the weeds from catching on things under the tractor.
   / Loader position #16
You mean like this?
Ah grasshopper...all isn't as it first seems. When fine grading or material spreading, the bucket lifted above the center point of the loader arm radius increases the ability to feel the "bubble in the butt." Really.
   / Loader position #17
My farmer neighbor has a 70 HP IH. He never takes off the FEL. He mounts the bush hog and then runs with the FEL up just because he wants the visibility. He also let me use it to do some of my property. It was like rock.
I, on the other hand, have tried running my MMM on my Mahindra Max25 with the FEL up and I didn't trust the stability. So I only raise my when I am getting near an obstruction.
As for dropping the FEL -- I have too much crap on the property, so if I find something I need to move I can use the FEL as a "garbage bucket".
   / Loader position #18
You mean like this?
RD, sometimes when you feel the "bubble in the butt" it isn't really a bubble.. It is something else, and you need to be careful.:eek:
   / Loader position #19
Not quite sure what you mean...but I bet its not good! :laughing:
   / Loader position #20
Pretty darn sure what you mean, and I know it's not good.:eek::yuck::laughing:
New/Unused CFG Industrial H15R Mini Excavator (A57453)
New/Unused CFG...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2023 Kubota KX057-5 Compact Excavator with Angle Blade (A56435)
2023 Kubota...
2025 BrushFox XHD72 72in Rotary Brush Cutter Skid Steer Attachment (A56857)
2025 BrushFox...
2015 International Durastar 4300 SBA 4 x 2 Water Truck, VIN: 3HAMMMMN4FL510006, Cummins Turbo Die... (A59076)
2015 International...
TCM FD30T6T 5,600lb Forklift (A55973)
TCM FD30T6T...
