Loader options for Ford 641?
/ Loader options for Ford 641? #1
moses6x6
SE Wisconsin
Case IH DX45
I own a Ford 641 Workmaster (HD front end) that is in excellent condition that I'd like to add a full hydrolic loader to. I know that I'd need to add an auxillary pump.
I'm looking for advice on what my options might be? Are there any manufacturers that make a new loader for this 40 year old tractor?
/ Loader options for Ford 641? #2
I hope you have power steering? I had a 640, same tractor basically. I had a Wagner WM3 loader, old style loader, no down pressure. I think there are many options for you. I have seen new loaders, say offf of mid 80's thru 90's Ford tractors on the 600 thru 900 seres. I have attached a picture of mine. I have since sold it because of the power steering issue, this unit used a front pump.
Good Luck,
Bill
/ Loader options for Ford 641? #3
I did a little more research, and Bush Hog offers a unit. Now I am sure there are others too, but this was the one I saw first. I called them, the model they offer for the 600/601 series Ford Tractors is as follows; frame #2346 $3058, mount kit $822, then you need to pick a bucket, joystick and pump. These are list prices they gave me, you could find a better deal.
My 2 cents, makes me think like this. The tractor you have right now is probably worth in the range of, $2500-$3500. Looks like you could spend at least $4500-$5000 on a loader. And you will have a tractor that you will never get even close to getting the money back on. What I did was sell my 640 tractor and get one with a loader on it. You can pick up a nice, say Ford 1710 or 1910, in the neighborhood of $5000 to $8000 with a loader and 4 wheel drive. Or better yet, keep the 641, and get a new tractor anyway!
Kwik Way might have a loader too. Picture attached of what I replaced my 640 with, it is a 85, Ford 1910 4wd loader and backhoe(pic w/o hoe)
Bill
Yes, it does have power steering. It is a great tractor with very few hours. I am the second owner. The first only used it to clear snow on an asphalt drive. It has always been stored inside. I don't want to get rid of it if I can find an affordable option for a loader. I do agree with you that I'd never get the $ out of a $4000 loader if I ever sell it. Thanks for the leads. I'll do some more research. This will help me when I talk to my implement dealer.
/ Loader options for Ford 641? #5
I have a cousin who has a Ford loader for this model tractor that he no longer uses. He may sell it, it is located in WV though.
/ Loader options for Ford 641? #6
Here is a 660 i own with a ford 722 front end loader. it's a 1-arm job.
Uses the built in hydro pump on the tractor ( 4gpm ).. is hyd up, and hyd tip/curl... thus it needs a dual spool with one DA, and one SA port. The dual valves that fit the top cover of the hundred and thousand series fords are still available.
I am in the process of purchasing an 850 to drop another 1-arm loader on, a 711.
Here's a pic of the 722 on my 660 lifting a bale of hay..
Then a pic of the 711 as i bought it from a junk dealer.. and how it now sets.. waiting for a tractor to hang it on..
Soundguy
2011 Chevrolet Silverado 1500 Work Truck (A62613)
2011 Chevrolet...
2013 FORD F-350 SUPER DUTY (A65643)
2013 FORD F-350...
Landhonor Mini Skid Steer (A60352)
Landhonor Mini...
2003 Toyota Tundra Extra Cab Pickup (A62613)
2003 Toyota Tundra...
78in Caterpillar Skidsteer Tooth Bucket (A65579)
78in Caterpillar...
2010 WABASH 53X102 REFRIDGERATED TRAILER (A59914)
2010 WABASH 53X102...
