loader on Tu180-240
/ loader on Tu180-240 #1
lens12
Dixon, Il
ford 9700, tw30, massey, jd2030 jd4010, yanmar F60d, ym330d, ym276d,ym226d,ym186d, ym2000, ym155
Has anyone mounted a loader on a TU180/200/185/205/220/240 ? If so what mounting brackets & loader did you use?
/ loader on Tu180-240 #2
Yes, we used Koyker but unfortunately long ago only the 140 was available and it was too big. When the 125 came out we changed to it instead. Now we use the Frey ML165 which fits perfect but it is still not a very good tractor for a loader as I am sure you know.
Buck
/ loader on Tu180-240 #3
Guys.. How do you tell if a tractor is a good tractor for a loader?
Thanks..
I don't like to put loader on tractors with aluminum or steel clutch housings without a sub frame. The TU180-240 clutch housing & transmission are not bolted together. They have a driveshaft & frame rails connecting them. I would recommend a sub frame on this style also.
/ loader on Tu180-240 #5
Thanks..
TU models have a setback front axle which is good for tight turning but bad for loader stability. TU frames are parameter thin wall extruded tube with a rubber mounted engine just like a car. To put a loader on you have to build a completely separate frame like Len said.
Buck
International S1900 (A63689)
International...
John Deere 920 (A64126)
John Deere 920...
Prime 283 (A64126)
Prime 283 (A64126)
2019 Ford F450 Extra Cab 4x4 Service Crane (A62613)
2019 Ford F450...
Bobcat E80 (A64126)
Bobcat E80 (A64126)
2022 John Deere X730 Lawn Mower (A63116)
2022 John Deere...
