loader on Tu180-240
/ loader on Tu180-240 #1
lens12
Dixon, Il
ford 9700, tw30, massey, jd2030 jd4010, yanmar F60d, ym330d, ym276d,ym226d,ym186d, ym2000, ym155
Has anyone mounted a loader on a TU180/200/185/205/220/240 ? If so what mounting brackets & loader did you use?
/ loader on Tu180-240 #2
Yes, we used Koyker but unfortunately long ago only the 140 was available and it was too big. When the 125 came out we changed to it instead. Now we use the Frey ML165 which fits perfect but it is still not a very good tractor for a loader as I am sure you know.
Buck
/ loader on Tu180-240 #3
Guys.. How do you tell if a tractor is a good tractor for a loader?
Thanks..
I don't like to put loader on tractors with aluminum or steel clutch housings without a sub frame. The TU180-240 clutch housing & transmission are not bolted together. They have a driveshaft & frame rails connecting them. I would recommend a sub frame on this style also.
/ loader on Tu180-240 #5
Thanks..
TU models have a setback front axle which is good for tight turning but bad for loader stability. TU frames are parameter thin wall extruded tube with a rubber mounted engine just like a car. To put a loader on you have to build a completely separate frame like Len said.
Buck
2014 VOLVO A40G WATER TRUCK (A62129)
2014 VOLVO A40G...
2023 Case TV450B (A62177)
2023 Case TV450B...
New/Unused Quick Attach Auger (A65583)
New/Unused Quick...
2007 TRAILMOBILE 53X 102 T/A DRY VAN TRAILER (A59914)
2007 TRAILMOBILE...
2018 JOHN DEERE 844K-III AG HANDLER WHEEL LOADER (A65053)
2018 JOHN DEERE...
Quick Attach Backing Plate (A65579)
Quick Attach...
