loader on tractor sinking down
/ loader on tractor sinking down
what do you mean by 'base line' ? just wonderin
/ loader on tractor sinking down #12
Opposite the rod end.
oh ok man.
/ loader on tractor sinking down #14
Like jj said cylinders need a repack
alright
/ loader on tractor sinking down #16
Does your directional control valve have cables to operate or is it all mechanical linkage? From what you are describing it sounds like the valve may not be centering properly all the time. This can be from moisture in the control linkage, moisture in the spring caps on the end of the valve spools etc. If the valve is not leaking and the cylinders are full of fluid the loader cannot leak down fully even with bad seals on the cylinders.
mechanical i would imagine. im just curious as to what would cause it to happen. it only happens every once in a great while. usually when i set the bucket curled under over night, like when the oil goes back 'into' the tractor it sucks air in the system
INTERNATIONAL FLAT BED TRUCK (A52707)
INTERNATIONAL FLAT...
CFG Industrial H15R (A60463)
CFG Industrial...
10 Safety Systems Barricades (A59317)
10 Safety Systems...
2005 Ford F-450 Dump Truck, VIN # 1FDXF46P65EB16866 (A61165)
2005 Ford F-450...
1009 (A61166)
1009 (A61166)
2012 GROVE TMS900E TRUCK CRANE (A58214)
2012 GROVE TMS900E...
