Loader Mount Snowplow???
/ Loader Mount Snowplow??? #1
Vince
NE Pennsylvania
Kubota L3430HSTC/Ags./turfs - Ford 8N - JD 445 - JD 316
I am going to purchase a Kubota L3430HSTC with LA723 loader, 72"bucket W/Skid Steer type coupler. This tractor will be used in N E PA winters for snowplowing with rear blade and loader mount blade. Rear blade for backing up to garage and barn doors and dragging snow...front for 1500' driveway and turn arounds (200' blacktop..1300' millings). What loader mount power angle plows do you fellows recommend and use? Also don't want to bumpbumpbump on driveway; so, should I avoid ag tires? Primary use of tractor..mowing 10 rolling acres. Thanks!
/ Loader Mount Snowplow??? #2
Tires: R4s
Snow plows: In my mind, only two choices: Sno-Way or Snow Wolf. Both manufacturers make good products, but Sno-Way has this trick, clear polycarbinate (sp.?) moldboard! Best of all, its replaceable. Not that it needs to be, since the Sno-Way folks eagerly hand you a 5-lb. sledge hammer to TRY to inflict damage on it!
/ Loader Mount Snowplow??? #3
I don't know what the experts like to use, but a couple I've heard of for tractors is Curtis and Kasco. I bought a Kasco at the tail end of winter here, and didn't really get to use it much. I don't have a skid steer mount, however the Kasco has brackets made specifically to fit my Branson quick attach loader. It's a 5 minute job to put it on. I got it so I could keep my backhoe on if I wanted. I use chains on the front tires to navigate my hills. Kasco is in Indiana.
sassafraspete
/ Loader Mount Snowplow??? #4
Also, this plow is pretty heavy...about 600 lb....so a rear blade is not nearly heavy enough to offset the weight...unless you have a way to add weight to the rear blade....eg I've seen some people weld brackets and put hanging weights, or even use bar bell weights on the rear blade. Weight is good on a plow though, as it helps in digging off the crud. Makes me wonder how well the polycarbonate plow would work...as seems it would be light.
sassafraspete
PORTA POTTY (A68842)
2017 Peterbilt 320 New Way 20ASL 20yd Side Loader Garbage Truck (A66736)
2017 Peterbilt 320...
1987 CAT D8N (A68134)
2012 KENWORTH TRIAXLE BODY LOAD (A67714)
2012 KENWORTH...
2005 INTERNATIONAL PAYSTAR 5600I HYDROVAC (A67714)
2005 INTERNATIONAL...
2018 MACK CXU (PINNACLE) (A67714)
2018 MACK CXU...
