Loader lift capacity issue
/ Loader lift capacity issue #1
GJHLAW
A little new, so bare with me, theoretically, when I am lifting a heavy load with the front bucket, and use my 3 point weight cement bucket to balance thectractor , am I taking away lift capacity from my loader?
/ Loader lift capacity issue #2
No. The rear weight also helps remove front Axel load. The only way you could notice a strain is if you were lifting (raising not holding)rear weight at the same moment that you were operating front loader. Even then depending on the load and your particular tractor pump setup I doubt you would have a problem.
/ Loader lift capacity issue #3
With weight hung off the 3PH you actually gain capacity. Without weight, most tractors have loaders strong enough to pick the back tires up well before the hydraulics are maxed out. Adding weight on the back allows you to lift stuff heavy enough to max the pressure out.
iDrive TDS-2010H...
Rotary Auger Motor Attachment (A61572)
Rotary Auger Motor...
2019 International LT625 Sleeper 48 (A62613)
2019 International...
2025 78in Bucket Skid Steer Attachment (A61572)
2025 78in Bucket...
2019 Cadillac XTS Stretch Limousine for Sale, S and S Coachbuilders, 70IN, 7866 Miles (A63688)
2019 Cadillac XTS...
2015 Ford F750 Service Crane Truck (A62613)
2015 Ford F750...
