Loader lift capacity issue
/ Loader lift capacity issue #1
GJHLAW
A little new, so bare with me, theoretically, when I am lifting a heavy load with the front bucket, and use my 3 point weight cement bucket to balance thectractor , am I taking away lift capacity from my loader?
/ Loader lift capacity issue #2
No. The rear weight also helps remove front Axel load. The only way you could notice a strain is if you were lifting (raising not holding)rear weight at the same moment that you were operating front loader. Even then depending on the load and your particular tractor pump setup I doubt you would have a problem.
/ Loader lift capacity issue #3
With weight hung off the 3PH you actually gain capacity. Without weight, most tractors have loaders strong enough to pick the back tires up well before the hydraulics are maxed out. Adding weight on the back allows you to lift stuff heavy enough to max the pressure out.
2017 Caterpillar 336F Hydraulic Excavator (A61572)
2017 Caterpillar...
BUSH HOG 2720 BATWING ROTARY MOWER (A64280)
BUSH HOG 2720...
2014 KUBOTA SVL75-2 SKID STEER (A64279)
2014 KUBOTA...
(2) UNUSED UNVERFERTH 8-10 WHEEL SPACERS (A64280)
(2) UNUSED...
(1) 30 GALLON (1) 100 GALLON OXY/ACETYLENE TANKS (A64281)
(1) 30 GALLON (1)...
2010 International 4300 Truck Altec DM47TR Insulated Material Handling Digger Derrick Truck (A64194)
2010 International...
