Loader Hydraulics (Left is slower than the right)
   / Loader Hydraulics (Left is slower than the right)
You know I was thinking of doing this yesterday and sounds like a great option.
Don't forget I swapped the cylinders yesterday with the same slow results from the right cylinder.
   / Loader Hydraulics (Left is slower than the right) #13
Can you make the relief valve activate using bucket curl, up and down?
If you cain't, then one or both cyl are weak.
   / Loader Hydraulics (Left is slower than the right) #14
Are the cylinders hooked to anything when you are testing them for speed?
Could be a something in the lines or hoses causing more flow to one cylinder vs the other.
For the test I didn't have them connected to anything, I will check the left hose there is one that was left behind from the cylinder swap.
   / Loader Hydraulics (Left is slower than the right) #16
Do if you did the test with the cylinders not hooked to anything at all and the right was slow. Then swapped cylinders not attached to anything at all, and the right was still slower??
For now that rules out anything mechanical with the loader cause they werent hooked to anything. And would rule out the cylinder. Only thing left is the individual lines. You should have 2 lines coming off the valve. One for curl and one for dump. They should each go into a tee somewhere and get split between the cylinders. You need to look between the tee and the cylinder.
But I would also caution you to make sure you got all of the air bled out of the system.
So I don't know a whole heck of a lot on hydraulic however I would assume both cylinders be pretty evenly matched when nothing is connected on the downward stroke and back stroke right?
   / Loader Hydraulics (Left is slower than the right) #18
Provided all the air is out of the system, they should be close. The one that has the longest hose after the tee could be a little slower. But fluid is going to take the path of least resistance. The loader frame should be rigid enough with both hooked up to overcome whatever small differences there are in the cylinders, provided they are both the same size.
Do the cylinders look like they are an identical matched set? or did someone change one at some point, perhaps to a slightly larger one. like going from a 50mm cylinder to a 2" cylinder??
Do you have any actual pictures and not the parts diagram of your loader, cylinders, and the part you are breaking. I am having a hard time getting a visual.
   / Loader Hydraulics (Left is slower than the right) #19
One more time, will the loader valve activate the relief when you use the curl cyl?
If so, then the cyl are performing up to the set relief.
If even one cyl is leaking, you probably will not be able to hit relief pressure, and you are working at the leaking cyl performance level.
If you have QD's, re-set them.
Did you try the curl cyl in the lift cyl work ports?
I drilled out the 1/4 inch sheer pin holes on the equalizer bar to 3/8 and put in 3/8 grade 8 bolts it seemed to do the trick from earlier mentioned in the post. I will fully test this weekend have a few buckets of dirt to move.
Many thanks for all your responses.
Magbag
2016 KENWORTH T270 SERVICE TRUCK (A51406)
2016 KENWORTH T270...
(35) 2" X 2" X 4' TUBING (A54756)
(35) 2" X 2" X 4'...
BELSHE DT-235 (A53843)
2014 Ford F-150 4X4 Ext. Cab Pickup Truck (A55788)
2014 Ford F-150...
(2) LITHONIA LIGHTING LUMINAIRE FITTING LIGHTS (A54757)
(2) LITHONIA...
49205 (A55788)
49205 (A55788)
