Loader Hydraulics (Left is slower than the right)
   / Loader Hydraulics (Left is slower than the right) #1
magbag
Blairstown, NJ
John Deere 4500\460 Loader
I知 almost certain I purchased this tractor with this issue. I have a John Deere 4500 series tractor with a 460 loader.
Soon after I purchased it I noticed that the sheer pin had broken from stabilizer bar that controls bucket tilt\dump function.
Yesterday I swapped the right hydraulic cylinder to the left and then left to right, still after the swap the right is much faster.
Checked all the lines and no dents or bends. Fluid level is ok. No leaks. Fluid is fresh and clean.
This is really getting to be a pain when I take the bucket on and off the right is so much faster and I致e proven this is not a cylinder issues by swapping them.
If I replace the sheer pins it just breaks them off the first time so I've given up on replacing them.
I see there is an older post up on this site but leads to a dead end for a resolution.
Any thoughts?
   / Loader Hydraulics (Left is slower than the right) #2
What are the shear pins you are talking about?
IF the cylinders arent the issue, it sounds like you have a mechanical binding issue? OR siezed pin.
Any thoughts?
http://www.tractorbynet.com/forums/...03163186-460-loader-tilt-cylender-lag-460-gif
Check out this link its number 8 in the picture. Nothing is binding all parts are free checked all of them yesterday not worn bad at all.
   / Loader Hydraulics (Left is slower than the right) #4
Can you tilt the bucket by hand with very little resistance?
One cyl can be slower that the other due to piston seal wear.
Do you have a hyd gage?
Cap off one bucket cyl and read the max pressure on the operating cyl.
Then cap off the other one and check the remaining cyl for max pressure.
They both should cause the relief valve to operate.
If it is not a cyl problem, it has to be a mechanical one.
After reconnecting both cylinders after swapping I cycled both without anything connected and the left was very slow coming out. After about 8 inches it starts to move with speed on the down cycle and is the same on the return cycle.
   / Loader Hydraulics (Left is slower than the right) #6
The cyl having the least resistance will operate first.
   / Loader Hydraulics (Left is slower than the right) #7
Are you actually breaking part #8? Or are you breaking the pin that keeps it from rotating (part #4?)
If part #4, either it isnt pivoting like it should (where it should) or the loader arms are tweaked themselves.
Hopefully others will chime in and be of more help. As I am not familiar with that loader. But if the loader arms arent tweaked, and everything is well greased and rotates freely, you shouldnt be breaking anything
I do not have a gauge to test but will look into getting one.
Didn't I disprove a cylinder issue by swapping left to right though?
You can see clearly how fast the right moves faster than then left and the end result is sheering off the pins.
   / Loader Hydraulics (Left is slower than the right) #10
If he has been operating the loader that way for very long, with one cyl much stronger than the other, he has already tweaked something.
Check and see if the cyl is bypassing /leaking internally.
Case 1020 25ft Draper Head (A55301)
Case 1020 25ft...
2003Chrysler Town & Country Van (A55758)
2003Chrysler Town...
2012 LAMAR TRAILER 20 T/A UTILITY TRAILER (A55745)
2012 LAMAR TRAILER...
2009 Ford F-150 Crew Cab Pickup Truck (A55788)
2009 Ford F-150...
2025 Swict 84in Bucket Skid Steer Attachment (A55787)
2025 Swict 84in...
Case 1083 20ft Corn Head (A55301)
Case 1083 20ft...
