Loader hydraulic line--need quick help
/ Loader hydraulic line--need quick help #1
Blue Planet
CK3510SE--sprung a leak. 5-paw Kioti dealer closed till Tuesday. Non-5-paw dealers seem to only stock filters, etc. Does anyone know if a Kubota (or other?) line can be used? Are these things fairly universal? Dumb question: after I change it, any bleeding needed? Or just top off hydraulic fluid?
Thanks!
/ Loader hydraulic line--need quick help #2
Any hydraulic or tractor shop, regardless of brand, can repair it. Problem is going to be finding one on the july 4th holiday. The system should self bleed afterwards. Hoses are not brand specific
/ Loader hydraulic line--need quick help #4
Interesting spot for a leak. Did you pull apart, Teflon tape and put back together?. Did you crush it with something? As others have stated, take it off and bring to shop. I found a local hydraulic place one time and the put together a new hose for me
/ Loader hydraulic line--need quick help #5
Make sure that it just doesn't need to be tightened.
I had that happen once - connection had slowly unscrewed and started to leak. Just tightened it and it has been fine since.
/ Loader hydraulic line--need quick help #6
As Seville009 says tighten it first, it may just have worked loose. Had that happen before.
Also even if it is tight you may be able to tighten it a little more to reduce or stop the leak so you can use the tractor over the long weelend.
If tightening does not work drop the loader to keep the tractor mobile until you repair the hose.
/ Loader hydraulic line--need quick help #7
Yes, that most likely needs tightening. Before you do it, review safety around pressurized hydraulic lines, high pressure oil hitting you can cause miserable injury. The manual for your tractor will provide safety measures.
/ Loader hydraulic line--need quick help #8
Blue Planet,
Thanks for pic. It looks like there is hydraulic fluid where the connector is crimped to the hose, if so then tightening/ sealing connector is not the problem. Hoses are generic but threaded connections are not and contributor 5030 has good suggestions about who might be open on July 4 weekend. You will have to identify what the connector style is. Forcing another hose on with incorrect thread will permanently damage the thread on the elbow.
Kioti web site may have info on thread/ connectors they use.
Hydraulic systems are self bleeding since fluid return to a reservoir where entrained air floats to top and is vented and pump in fluid picks up fresh fluid. Check reservoir fluid level and top as appropriate.
Good luck
/ Loader hydraulic line--need quick help #9
By the way, I had a bucket hose bust on me one time when I was brush hogging. I just raised it up to about level and didn't use the bucket; I was able to still drive it without fluid spraying out.
I mention that in case you need to drive it. I don't recommend using it with it leaking - just saying that you will be ok to move it if you need to.
Thanks everyone for the advice! Pretty sure the leak is caused by--ironically--the helical wire guard cutting into the hose. Fittings are all tight.
/ Loader hydraulic line--need quick help #11
Fittings are British Standard Thread (BST). A good hydraulic shop will have them.
/ Loader hydraulic line--need quick help #12
Thanks!
A local jobber hydraulic shop or a good NAPA can make that little hose for you all day long. No. big. Deal.
Remove the hose and bring it into them.
After changing, just cycle the curl and it will self-bleed.
/ Loader hydraulic line--need quick help #13
Put a sock on the hose and toss the spiral guard. Had the same thing blow out one of my steering hoses on my NX series that was tight enough that I had to drop off my loader to go after it a couple of years ago.
/ Loader hydraulic line--need quick help #14
You can get premade hydraulic line at surpluscenter.com
Also, you might want to get into the Parker online catalog. I use it to look up part numbers, then google that and I often find the parts online cheap. Having a few extra hydraulic fittings on hand can save your weekend.
/ Loader hydraulic line--need quick help #15
True story. I keep an entire extra set of lines for my grapple and snow plow. Since I made my own third function, many of those lines are hard lines.
2008 Sterling Acterra 2,000 Gallon Water Truck (A66736)
2008 Sterling...
FUEL TANK (A68842)
FUEL TANK (A68842)
UNUSED FUTURE CAT 303 38" EXCAVATOR RAKE (A65055)
UNUSED FUTURE CAT...
PALLET OF SUMP PUMPS (A68842)
PALLET OF SUMP...
2007 HEIL TRAILER (A67714)
2007 HEIL TRAILER...
2019 Toyota Mirai Sedan (A66738)
2019 Toyota Mirai...
