Loader hydraulic issue
/ Loader hydraulic issue #1
Dirt1
Pa.
Massey 135 & Farmall Cubs
I have a MF 135 with some kinda homebrew FEL. The main lift cylinders on the FEL aren't exactly in sync with each other. The right side rises before the left, and the left side contacts the ground before the right. The issue has broken the welds on the cross members between the main lift arms.
I've had the cylinders rebuilt so thats not the issue.
Any ideas on a possible remedy is appreciated.
I don't have much hydraulic repair experience, so don't beat me up too bad.
Thanks
/ Loader hydraulic issue #2
Since the loader is homemade, do some measuring. Check center to center on each end of the cylinder mount pins to the boom pivot point. They should match side to side.
Try swapping cylinders and see if the problem stay the same, if so somethng is binding the slow side. If the problem changes sides, its a cylinder problem, bent shaft maybe?
Look at the boom pivot pins are the square to the boom? Parallel to the ground?
Pallet of Two Pivot Wheels & Tires (A62177)
Pallet of Two...
UNUSED WOLVERINE HYD BRUSH CUTTER (A64281)
UNUSED WOLVERINE...
2 Horse Trailer (A62613)
2 Horse Trailer...
2018 FORD F550 XL 6K LB SERVICE CRANE (A62613)
2018 FORD F550 XL...
2020 Ford Explorer AWD SUV (A61574)
2020 Ford Explorer...
3pt 4 Row Bottom Plow (A64119)
3pt 4 Row Bottom...
