Loader going up at half speed
/ Loader going up at half speed #1
albmn10
Albany New York
Kioti Ck30 Hst , John Deere L130
Was moving some logs last weekend and noticed the loader started going up at half speed. It lowers at full speed though. It was due for its 50 hr service so i changed all the fluids and it still went up at half speed. The loader is a woods 1012 on a cK30 hst. Any ideas?
/ Loader going up at half speed #2
Check that all your quick disconnects are seated properly. They can look like there seated but sometimes there not....
Don
/ Loader going up at half speed #3
I suspect the problem may be in the joystick. If you raise the boot up and watch what happens when you move the stick, you may see that the joystick is not moving the valve all the way.
I'd have it checked by the dealer as it is still under warranty if I'm not mistaken.
If the quick disconnects were not seated properly, you'd have more than just that reaction, so I don't think that's where the problem is.
Make sure the rounded heads on the valve under the boot haven't broken or slipped out of position.
John
2016 CHEVROLET IMPALA CAR (A66091)
2016 CHEVROLET...
2014 Dynapac CP142 9 Wheel Pneumatic Roller (A62679)
2014 Dynapac CP142...
1024 (A63111)
1024 (A63111)
2015 KENWORTH T680 (A67714)
2015 KENWORTH T680...
AIR GREASE PUMP W/STAND AND GENERATOR (A67714)
AIR GREASE PUMP...
2011 FORD CROWN VICTORIA CAR (A66091)
2011 FORD CROWN...
