Loader for 1300
/ Loader for 1300 #1
What companies make a loader to fit a Yanmar 1300?Would maybe like to put
a loader on mine
/ Loader for 1300 #2
Koyker makes an 80 that will fit it, but you will only get perhaps half the actual capacity/use of the loader due to the tractor's size. 2wd units in general also have a much lighter axle than the 4wd models, making them have even less capacity with a loader. It's certainly your call, but I would consider moving up to at least a 1500D or 1610D before installing a loader, considering that the loader is a sizeable investment.
/ Loader for 1300
Its a 4WD I have loaders on larger tractors (Oliver 1365,Ford 8000,AC 180)
but need a one on a real small tractor for tight places thanks
/ Loader for 1300 #4
Hello Hard Knocks,
I believe your 1300D is similar to my 155D. It came with a loader that I think is the stock Yanmar YFL-155 loader. I imagine it would be hard to find used. I do appreciate the compact size of the machine overall and the rounded bucket which make material less likely to get stuck in the corners.
/ Loader for 1300 #5
You'd have to fab up the brackets, but I mounted a kwik-way loader on my tractor. The size was perfect and it's self leveling too.
Unused 2024 Land Pride PF1242 42. Forks and Frame Skid Steer Attachment (A66734)
Unused 2024 Land...
Unused 2024 Land Pride PFL3048 48in. Forks and Frame Skid Steer Attachment (A66734)
Unused 2024 Land...
2024 CATERPILLAR 255 SKID STEER (A65056)
2024 CATERPILLAR...
2018 GENERAC MOBILE PRODUCTS MLT6S (A67714)
2018 GENERAC...
CASE TV380 (A67714)
CASE TV380 (A67714)
2016 Ford F-650 18ft Hydraulic Dovetail Hauler Truck (A61573)
2016 Ford F-650...
