Loader curl leak down
/ Loader curl leak down #1
lexluther
Redding
New Holland
Ok, I am a desk jockey who is a die hard DIY guy and loves his tractor time, so go easy on me, i have searched for an answer, but there is a reason i am confused, see below.
I have a new holland tc24 and the loader bucket curl doesn't hold. It was slow at first, but now, it leaks down fairly fast, even with no load, you can watch it go fully down in less than a minute. The problem has gotten worse since i first noticed.
Tonight I decided to try and solve it one more time before calling a mechanic...the problem is the same even when the lines are disconnected at the quick disconnect fitting. Not only does it leak down, but if I grab the bucket, I can lift it and get about half way up by hand. There are no visible leaks anywhere while doing this.
Here is the confusing part...when the problem was fairly minor, I had the cylinders tested by the local hydraulics shop, they said they were in spec and didn't need rebuild...I think perhaps they got busy and didn't really test them or my problem has progressed?
With the lines disconnected it's essentially a closed system right? And no oil on the ground means it has to be the cylinder that needs rebuild right?
Thanks a million for the help!
/ Loader curl leak down #2
You are correct. Just double check you are disconnecting the right lines. With the lines unhooked, that isolates the valve from the cylinders. With only the cylinders in the picture,and still drifting......cylinders are the problem.
The issue is the cylinders are tee'd together. So you could have an issue with only one cylinder and still have the same symptoms. Good idea to just have both rebuilt though.
Just curious, how many hours on machine?
/ Loader curl leak down #3
Rebuilding both curl cylinders should cure your problems.
/ Loader curl leak down #4
I had that same problem with my loader, it would go down just as fast as it went up and it was the seals. In my case it was just O Rings and shims and wiper seals at the cost of $15 for three cylinders. I think mine had been rebuilt with the wrong O Rings and were not ment to be in oil , who knows, but they came apart in my system which uses ATF type F . DSCF0441.jpg Not a hard job to do but messyDSCF0442.jpg
Thanks for the confirmation...There are about 350 hours on the tractor but it's about 15 years old. Previous owner didn't use it much, maybe 10 hours per year, i am getting closer to 100 per year. I got these really cool bolt on hooks I want to try, but the curl problem makes it difficult...thanks KennyD maybe it's time to try a new hydraulic shop if there is one.
/ Loader curl leak down #6
Sounds like you have control valve problem where the H fluid bypasses the valve.
/ Loader curl leak down #7
The OP wrote this:
So how is the valve the problem when the lines are disconnected?
/ Loader curl leak down #8
I agree that a better hydraulic shop is called for. Re-test and rebuild then test as necessary.
Valve was what I was worried about as it is a more difficult repair. I tested leakdown with the lines disconnected, it seemed no different than when the lines are connected. When I was lifting the bucket, the lines were connected, but I think I could hear the fluid in the cylinder if that's possible with a 5 year old boy in the shop...
/ Loader curl leak down #10
When I rebuilt mine on the Case Loader I did not remove the hoses, I did not remove the cylinder from the loader, I removed the pin on the bucket end then the clip holding the head on the cylinder, used a piece of pipe 2 foot long through the hole the pin came out off and pulled the ram out. Remove the nut from the end slide everything off and start replacing all the rubber parts. I always take pictures of what I am doing every step so if it can go back together two different way I can look at the pictures and pick the right one and also share with someone that need a little moral support. I drove a desk for eight years and I enjoyed fixing or trying to fix things more then .
/ Loader curl leak down #11
It is a bit of a puzzle as to where the volume of the collapsing ram goes as it slowly enters the cylinder while the bucket uncurls.
Strange that a system that should follow a PV relationship with the fluid building supporting pressure, just "disappears".
That is why we look to the valve, and why the OPs comments regarding no leaks are significant.
Where does the fluid go? Expanding the steel and flex lines?
Of course the cylinders could be sucking air as they extend. That would make the explanation easier. ;-)
I think with the lines disconnected it should act like two separate closed systems one for up and one for down. With no leak it wouldn't budge. The only place for the oil to get from one side to the other and hence move the cylinder is in the cylinder itself.
... I thought it could be sucking air too, but I think it would also be leaking oil on the reverse stroke
/ Loader curl leak down #13
My L35 was having a similar issue, but not near as dramatic in the speed, at which the bucket was letting down as you're experiencing.
Turns out, that my 25 year old hoses were letting air in, but no fluid out. Now, since I have had to replace 2 because of fluid containment failure - It's made a large difference in resolving my droop issue.
I figure what little let down I still have is likely due to still running off of 2 original hoses on that circuit, maybe/maybe not. Anyway, since they aren't that expensive, I might go ahead and replace both prior to complete failure like the others.
Just my experience. Your issue may be totally internal to the cylinders. Kind of sounds like that to me.
Hope you get things resolved,
B.W.D.
/ Loader curl leak down #14
The rod is pulling out of the cylinder. It sucks air around the gland seal to compensate and/or puts the cylinder under vacuum.....which like air.....acts like a compressible gas.
Curl cylinders drifting is a whole different animal than lift cylinders drifting. With curl, it indeed could be the cylinder or valve. By uncoupling the connectors, it isolates the two and tells you exactly where the problem lies.
The poster that said it was a valve issue, either missed that part in the original post....or doesn't know hydraulics
/ Loader curl leak down #15
When the seal that divides the two sides fails there is no up side and down side, they connect and become one with a little restriction . Bypassing around the seal. The seals went bad in the Power Steering cylinder on my Jinma and you had to slowly keep turning the steering wheel to keep it straight. Real pain in road gear meeting a car. Pictures shows the seal failDSC07328.jpgDSC07329.jpg.
/ Loader curl leak down #16
When the seal that divides the two sides fails there is no up side and down side, they connect and become one with a little restriction . Bypassing around the seal. The seals went bad in the Power Steering cylinder on my Jinma and you had to slowly keep turning the steering wheel to keep it straight. Real pain in road gear meeting a car. Pictures shows the seal failView attachment 488011View attachment 488012.
Rocky
You still need to account for the ram volume. In or out, plus or minus, there is no free lunch, moving oil from one side of the piston seal to the other is not enough.
Although it's a lot easier to explain when pulling things apart. Every material has a vapor pressure.
/ Loader curl leak down #17
I understand the logic...but the fact is there are 100's of post's and pictures documenting the fact that when cylinders have bad internal seals, the bucket drifts-did it on my machine once so I have first hand experience.
Also remember that there are two cylinders in parallel in most FEL setups, so that contributes too.
Edited to add:
Here is one such post from a local freind...one 0-ring was torn and the loader wouldn't stay up-rebuilding (in pairs is suggested) fixed it. Sometime real world experience trump's logic and books text's. I can reference more if needed.
http://www.tractorbynet.com/forums/...nders-deere-420-a.html?highlight=#post2314993
/ Loader curl leak down #18
It can be very difficult to separate science (physics) from magic.
But we can, if we try. An example without an accurate explanation is a poor learning tool.
/ Loader curl leak down #19
Ok, I'll be sure to remind Wayne when I see him next that rebuilding the cylinders really didn't fix his problem, the science said so. Oh yeah my loader must still be broken too, darn.
/ Loader curl leak down #20
Should be a good learning experience replacing the seals. take your time, take some pictures, ask for help when needed.
2023 VOLVO VNL760 6X4 T/A  SLEEPER TRUCK TRACTOR (A59908)
2023 VOLVO VNL760...
2019 Ram 2500 4x4 Crew Cab Pickup Truck (A60352)
2019 Ram 2500 4x4...
1974 Ford F600 Grain Truck (A61307)
1974 Ford F600...
2025 Pabreak 6-Way 84in. Serrated Hydraulic Dozer Blade Skid Steer Attachment (A61567)
2025 Pabreak 6-Way...
2004 INTERNATIONAL 7400 20FT TANDEM AXLE FLAT BED (A59906)
2004 INTERNATIONAL...
2017 International HX620 Quint Dump (A62613)
2017 International...
