loader control
/ loader control #2
Welcome to TBN
What is the problem with the valve? Only things that can be repaired on a spool valve is a leaking seal or faulty relief valve. If spool is leaking internally complete valve assembly must be replaced to correct problem.
/ loader control #3
Go to
https://mahindrausa.com/#
Have your tractor serial number at hand.
Go to the menu item "Owner."
I do not have a Mahindra but was told with a serial number you get access to more stuff than a regular guy can.
I am with Tx Jim in saying not much can go wrong with the FEL valve body itself. If yours has a joystick, some are cable operated to the valve and things come loose causing operational problems.
Dave M7040
2017 Ford Transit 250 Cargo Van (A64556)
2017 Ford Transit...
KUHN GA4121GM 11' ROTARY HAY RAKE (A64277)
KUHN GA4121GM 11'...
2019 Westinghouse WSTBT1503 Wireless Speaker (A61574)
2019 Westinghouse...
Kubota V3600-T-E2 Turbo Diesel Engine - 3.6L - 84 HP - 2018 - Tier 2 - Pump Takeout (A63689)
Kubota V3600-T-E2...
2014 Ram 2500 4x4 Crew Cab Pickup Truck (A64194)
2014 Ram 2500 4x4...
2007 INTERNATIONAL 4300 4X2 S/A UTILITY BODY TRUCK (A66091)
2007 INTERNATIONAL...
