Loader control valve leak.
/ Loader control valve leak. #1
brokenknee
Platinum Member
South of Moose Lake MN
The other day my control valve started to leak. It turned out to be leaking from an allen screw. I tightened it up and it stopped leaking, but now I am wondering if by tightening the allen screw if it made any type of "adjustment" to the loader hydraulics.
/ Loader control valve leak. #2
I suspect that is just a plug used to close off a drill path in your valve. If you are concerned carefully remove it to see if there is any springs, etc. under it. From its position it could possibly be a gauge port.
/ Loader control valve leak. #3
I believe the allen screw should be tight.
I can't think of a situation where an allen head screw is used to adjust something. They are usually tight.
If an allen screw was used, it would need something to lock it in place, maybe thread lock or another screw on top of the allen screw.
A good manual is always useful.
Sorry for the late response, have used the tractor quite a bit lately moving the spoils of my pond dig. I did not pull the allen screw out again. The loader appears to work as before so all it fine. Thanks for the replies.
Kuhn FC 4000 (A64126)
Landhonor Quick Attach Tree Puller (A66285)
Landhonor Quick...
2007 DRAGON 130BBL STEEL (A60736)
2007 DRAGON 130BBL...
2018 Kubota RTV 900 4X4 (A62613)
2018 Kubota RTV...
1970 Freehauf Lowboy, 20' Deck with 3' Dovetail (A62679)
1970 Freehauf...
Manure Spreader (A65640)
Manure Spreader...
