Loader Bucket rises slow
/ Loader Bucket rises slow #1
hb1
Lanse MI
Kubota 3710
I have a 2000 Kubota L3710. Today the front loader started to rise very slow. Oil seems to be fine. Would it be the pump? Any way to check? Not sure where to start.
Thanks for reply
I looked at the tractor today. The loader is working normal but the three pt hitch is still not working. I am not sure where to look next.
/ Loader Bucket rises slow #5
I'll look tomorrow in the manual and see what way the hyd block valve should be turned. I can't remember if it shuts down the 3pt if turned wrong. Bty it's under your right foot.
Thanks
/ Loader Bucket rises slow #7
When my loader started acting that way shortly after I bought it I found the oil on the stick looked fine but when I drained it the oil was very dirty. I guess the previous owner never changed it. After the change the loader worked fine. Took a little time to get all the old oil out. Changed the oil twice with cheap oil to flush then went with Kubota'a SUDT2. All is well.
Thanks for reply
/ Loader Bucket rises slow #9
Hb I forgot about it yesterday and was out of town today, well try tomorrow. The parts list is to big to load on here. other wise I would sent that to you.
/ Loader Bucket rises slow #11
The picture is just so you can see the system, if you don't have rear remotes then #2 would go right to #4.
The other picture is the hyd block. After reading it does seem to shut down the 3pt if you do not have rear remotes.
WOW it didn't scan the red line. There should be a red line from #1 to #2 then to #6, from #6 to #7 and also from #6 to #4 then last one #5
1043 (A60430)
1043 (A60430)
2006 CATERPILLAR 307C EXCAVATOR (A63276)
2006 CATERPILLAR...
2023 CATERPILLAR 320 EXCAVATOR (A62129)
2023 CATERPILLAR...
2019 Toyota Mirai Sedan (A61574)
2019 Toyota Mirai...
2006 Mack CV713 Flatbed Truck (A62679)
2006 Mack CV713...
2018 Trail King Lowboy (A63689)
2018 Trail King...
