Loader bucket plan
/ Loader bucket plan #1
sbr
WA
MF35
Does anyone know of a plan that i can use to make a 5' bucket for my loader. I cant copy my old bucket because i dont have one.
Thanks
/ Loader bucket plan #2
Out in Oso, Wa just off of highway 530 guy by the name Sid has a shop that bent my 6' bucket up. I then welded it up.
Bought a 5' X 8' sheet fron Everett Steel. Took it over to him and told him what I wanted and He explained what I needed instead. Worked out great
/ Loader bucket plan #4
When I made mine, I sketched out several ideas on graph paper and when I decided on which I liked best, I converted the measurements to feet/inches then made a mock up out of cardboard, just to make certain I was satisfied with it's size, design and appearance. Whole process took an hour or two.
/ Loader bucket plan #5
Go and visit some friends with loaders, or head over to an implement dealer and pick up some literature. The internet has unlimited information.
Often times farm tractor loaders have a different bucket design/shape than a construction machine as well as being lighter in weight for the same size.
While you can dig with a farm tractor, it is designed more for moving material than rough digging or handling rock and concrete all day long. Not that you can't do rough work with a farm loader, but it will generally break sooner than a construction machine.
With all that in mind, take the best design that you like and scale it to your machine. Of course the mounting will have to be designed around your machine specifically. Usually the width on a general purpose bucket will be a couple of inches wider then your machine. A bucket for handling wood chips, or snow is usually larger and wider for handing lighter materials, but can overload a machine handling gravel, etc..
Most fab shops can shear/cut the steel and also bend it based on a set of sketches. As a bonus, they probably have already built one or two previously, and can make adjustment or suggestions to potential issues. Bring it all home and spend a day or two welding and painting. They probably either stock or can get a cold rolled cutting edge easily.
Many folks use the Google sketch program for designs, although I have not used it having access to AutoCAD myself.
/ Loader bucket plan #6
Find a bucket you like and make a cardboard template of the side plates.
I made the bucket in the pic for my backhoe. I had a 12" bucket and needed a 6" so I made a template and it works great.
2019 CATERPILLAR M316F MOBILE EXCAVATOR (A63276)
2019 CATERPILLAR...
LONG 10 WHEEL V-RAKE (A64278)
LONG 10 WHEEL...
2021 Kubota SVL75-2 Track Loader (A63689)
2021 Kubota...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
2018 BOBCAT MT85 STAND-ON SKID STEER (A65053)
2018 BOBCAT MT85...
2019 Polaris Ranger Crew XP1000 4x4 Gas Utility Cart (A64557)
2019 Polaris...
