Loader boom cylinders uneven
   / Loader boom cylinders uneven #21
Everyone worries about an uneven load possibly bending loader parts like the boom arms, torsional support tube, or the bucket pivots. Those are hard to bend, but always a possibility.
Actually.... they're not that hard to bend.
Running stress tests on backhoes years ago, I was AMAZED at the differences in the stress generated between a pro operator and an amateur (like me) doing the same load cycle. You THINK you're smooth and being easy on the equipment until you look at the stress curves. Ha!... FULL of spikes.
Given that the machines we own are fairly light duty, the loader frame is especially vulnerable, and few of us make a living using them... a loader is not that hard to tweak. Hopefully the OP just has a mounting issue. JMHO
   / Loader boom cylinders uneven #22
My thoughts on the issue is there’s two possible causes. First is the cross tube is bent/twisted as others have suggested. OP however doesn’t feel there’s been any misuse to cause this. Second possibility I think could cause the uneven extension of both cylinders is the right side piston seal is shot causing a unequal force of the two boom cylinders.
   / Loader boom cylinders uneven #23
The cylinders are just plumbed together with a T and don’t have flow dividers. If one cylinder is bleeding off pressure it will make both sides equally weak.
   / Loader boom cylinders uneven #24
The pressure in both cylinders will be equal in both cylinders because there plumbed together. The cylinder with the good seals will convert this equal pressure into more force than the cylinder with bad seals .
   / Loader boom cylinders uneven #25
Equal pressure in both cylinders will make equal force from both cylinders. If the leak was bad enough there wouldn’t be any pressure and you wouldn’t have any lift from either cylinder.
   / Loader boom cylinders uneven #27
Have you checked tire pressure? Not likely, but the the machine could be a little off & you are only noticing it on the loader. It would be the rears not the fronts as they are mounted solid. The pivoting front axle provides no stability & everything comes from the rear.
Not ruling out the loader being tweaked, but easier to check & remedy.
   / Loader boom cylinders uneven #28
If the gland nut threads were stripped the glands would blow out of the end of the cylinder. The loader cylinders have no form of synchronization anyway. You should stick to giving advice on subjects that you have the slightest idea of what you’re talking about.
Why do you have to be such a jerk about it? Have you not ever made a mistake?
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
2017 John Deere 5090GN (A53317)
2017 John Deere...
1713 (A58375)
1713 (A58375)
2022 Schulte 2500 Giant Rock Picker (A56436)
2022 Schulte 2500...
2182 (A58376)
2182 (A58376)
2005 Ford F150 Pick Up (A55272)
2005 Ford F150...
