Loader boom cylinders uneven
   / Loader boom cylinders uneven #1
Ken P
North Granby, CT
Kubota B2410
Folks - I was taking my loader (LA 352) off my B2410 today (to put on the snowblower) and noticed that the boom cylinders were uneven. That is, the clutch side boom cylinder was pushed out more than the left. It was very difficult to remove the loader, also - one side came off and the other didn't, until I horsed around with it quite a bit. Nothing leaking. No accidents or problems up until today.
Could anyone point me to how I go about diagnosing and (hopefully at home) repairing? Much appreciated -
Ken in North Granby, CT
   / Loader boom cylinders uneven #2
Sounds to me like the gland nut threads are stripped, then the hyd. oil got out of balance in the cylinder.
   / Loader boom cylinders uneven #3
The cylinders are self equalizing, the mounting brackets/loader assembly are what keep them even.
I assume this issue was before the loader was removed.
If so, its possible the mounting brackets have shifted, also possible the frame has been tweaked. Brackets would be my.first guess though.
You can reset them my parking on a hard flat surface (preferably flat concrete) and with the loader mounted and bucket grounded, lossen the mounting bracket bolts then re-torque them to specs.
You may have to move the bucket a little while the bolts are lose to shift things around.
Sent from my SM-S921U using TractorByNet mobile app
Garden Tiller (A57454)
2016 JOHN DEERE 310SL BACKHOE (A52709)
2016 JOHN DEERE...
SET OF PALADIN JRB 60" PALLET FORKS (A52707)
SET OF PALADIN JRB...
Central Machinery Horizontal/Vertical Bandsaw, S/N 366852447, 120 Volt (A59076)
Central Machinery...
Flatbed Truck (A55973)
2021 Honda Pioneer 4x4 Utility Cart (A56857)
2021 Honda Pioneer...
