Loader bolts on CK30HST
   / Loader bolts on CK30HST #1
HODAK
NE Pennsylvania
CK30HST
Just did the 100 hour oil and filter change and checked all of the loader bolts among other items. The bolts located toward the front of the tractor right next to the oil filter were a little loose. All of the rest including the ones at the pivot points were good. The loader had some fairly hard use for about 50 of the 100 hours. Leveled many loads of dirt. Thanks Rick Wallace /forums/images/graemlins/smile.gif
   / Loader bolts on CK30HST #2
How about those wheel nuts, any loose there?I had 2 that loosen up on me, I keep an eye out every couple of hours...cag
   / Loader bolts on CK30HST #3
I usually grease my loader after about 4 hours of use, and check the bolts at that time. Be careful not to overtighten some of the bushing bolts. I twisted one off the first time I retightened.
Bolts can sure loosen up with some of the hard work we do with these tractors.
It also it is a good idea to blow out your radiator and prescreen often too. Be careful not to use too high pressure when blowing around the fins.
John
2020 Kubota RVX900 4x4 Utility Cart (A59228)
2020 Kubota RVX900...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
2017 KINZE KNOTCHED SINGLE DISK FERTILIZER OPENER FOR 3000/3500 SERIES PLANTERS (6 ROWS) (A55315)
2017 KINZE...
Dvorak Model 3072A Hydraulic Ironworker S/A Towable Trailer (A59228)
Dvorak Model 3072A...
2013 CATERPILLAR 299D SKID STEER (A60429)
2013 CATERPILLAR...
2021 XCMG CV123PDU ROLLER (A60429)
2021 XCMG CV123PDU...
