Ballast loader ballast
/ loader ballast #11
Carl,
What bucket size??
Since most FEL are to match the tractor rear wheel base {not unless you have little extra $$$ or know of a good welder} I think you have to take what comes.
Ballast?
I always like the ballast on the rear end or wheel weights. I never been a big fan on loaded tires, had tractors tires loaded on the farm and if you need tire repaired it extra down time.
That way if the ground is soft a can drop the extra weight etc..
Bucket in snow?
The first winter I try a bucket for snow removeal, and the second winter I purchase a plow and made plow frame that attaches to my bucket...and clean up time was cut in half also cleaner snow removeal job done all the way around.
A wider bucket {at least 12inches} for snow removeal would be nice,and maybe a tractor company etc... has one on the market for a compact tractor,but I yet to run across it /w3tcompact/icons/blush.gifand the price might /w3tcompact/icons/shocked.gif me.
Thomas..NH /w3tcompact/icons/wink.gif
/ loader ballast #12
<font color=blue>Re: I think you have to take what comes</font color=blue>
Thomas, you frequently do have some options on the bucket for a front end loader. I have the "standard" 54" bucket on my B2710, but a 60" "light material" bucket was an option.
Bird
/ loader ballast #14
Bird,
Your right about me expressing my views about a bucket for a front end loader,and it got me to thinking..oh no./w3tcompact/icons/shocked.gif
Maybe its do to living on a farm and having to operate Farmall H with a manure bucket that had a hand trip lever...which never work good in cold weather also the bucket never really did a good job./w3tcompact/icons/frown.gif..but I guess it was better than useing a wheel barrow 100% of the time. /w3tcompact/icons/smile.gif
In your view what would you consider the use of light material bucket?
My thoughts, sand..light brush..light snow.. etc...
When I purchase my B7100 there was no option on a bucket./w3tcompact/icons/frown.gif Did you have an option when you purchase your B7100?
/ loader ballast #15
Thomas, when I bought my B7100, nothing in the documentation that I saw said anything about there being any optional buckets for the B1630C loader (48" bucket), and it never occurred to me to ask.
When I bought the B2710, the sales brochure listed both 54" and 60" buckets with no information except the size (the 60" is also deeper and taller, but only weighs 7 lbs. more - reckon it's lighter or thinner metal?). The shop manual lists them as a "54" and a "60LM". So when the salesman asked which bucket I wanted, and I asked the difference other than the 6" width, he looked in one of his books and said the "LM" meant "light material" but he didn't know what that meant. I didn't pursue the matter further because I figured the 54 was what I wanted anyway. So I guess the simple answer to your question is "I don't know."/w3tcompact/icons/frown.gif/w3tcompact/icons/smile.gif
Bird
/ loader ballast #16
Thomas,
I don't know about Deere but when I bought my 60 inch "general purpose" bucket for the 'bota there was also an optional "heavy duty" bucket that weighed 200 lbs more (and cost more). I assume the extra weight was a heavier guage steel all the way around.
/ loader ballast #17
Carl,
You are getting good advice and I'll throw in my ditto'as well.
Beside the FEL I have a box blade, a rotary cutter and a backhoe. The box blade and backhoe are the primary implements hanging off the 3PH. The box blade I have is Dirt Dog brand out of GA and to throw it in a catagory its a medium duty implement. It's built tuff but it was cheaper than other brands but not to cheap. It does the job so far.
Since you can push backwards as well as pull forwards with a box blade it might be a more usefull implement than the blade. But the box blade and the blade have the good points and bad but I figured for me the box blade was the way to go.
Another thing to consider is to use a hydraulic top link for your 3PH. I would assume it would be usefull for a blade. I KNOW it is a real must have for a box blade. You can adjust your boxblade without leaving the seat and while you are moving stuff around. Its a MUST have.
Also consider a 4n1 bucket for the FEL. You will have to be carefull with this because of the extra wieght of the bucket . The 4n1 bucket might take a good percentage of the lift out of your FEL on a smaller tractor. HOWEVER, the 4n1 is one of my most used implements. I was telling someone this weekend that without the 4n1 I think I would be only getting 50% of the capability out of the tractor. If you have anything to grab like wood, rocks, brush, etc., the 4n1 is the answer. The 4n1 can also be opened all the way so you have a "dozer" blade on the FEL. I use the "dozer" function to push stuff all the time.
However, if you do want a 4n1 bucket and a hydraulic toplink you will have to get the third SCV for the tractor and some other plumbing.
But again it really depends on what you are going to use the tractor. If you don't need to pick stuff up or push things often then you might not want the 4n1. If you have a gravel driveway to maintain then a box blade or blade is a usefull tool.
Ask the dealer about the new latch for the front of the JD FEL. I have a JD 4700 with a 460 4n1 FEL. JD is supplying, maybe after the purchase, a latch the holds the FEL L plate(my name for the gizmo) onto the front weight bumper. I'm assuming the FEL you are looking at works the same as the 460. The 460 has a L shaped piece of metal that locks over the front wieght bumper. There is a lever on the left side of the FEL that is used by the tractor operator to open and close the L shaped bracket over the wieght bumper. It is used to remove/attach the FEL to the tractor. The new latch fits over both the wieght bumper AND the L shapped bracket locking the two togther.
It really is easy to see and use but far harder to discribe. :cool: Just make sure they give you the latch. Even without the latch if everything is adjust the FEL is really secured on the wieght bumper. The latch just makes sure it ain't going anywhere. :cool:
The JD FEL is VERY easy to take off and and put back on.
Hope this helps...
Dan McCarty
2022 FORD F-250 STX CREW CAB TRUCK (A59823)
2022 FORD F-250...
2012 Ford F-250 4x4 Pickup Truck (A60352)
2012 Ford F-250...
iDrive TDS-2010H...
TANK MANIFOLD (A55745)
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2018 FREIGHTLINER...
2022 John Deere Z930M (A57148)
2022 John Deere...
