loader arms!
/ loader arms! #1
peter3759
Eden, NY
LS R4041H
When i detach my front end loader today to do some brush hogging i noticed that the cylinders on each side were moving at different rates! Is this because the hookups are on one side so that side gets better flow due to not having to lift the weight of the loader?
/ loader arms! #2
+ other variables.
when you actually have something attached to FEL (bucket, forks, etc..) the smaller differences dis-appear. and everything should move equally. more so when there is a load on the FEL.
/ loader arms! #3
It's completely normal for that to happen. Often there is a timing rod that runs between the two side to help keep them together, the JD's have small pins in these rods that are well known for breaking.
/ loader arms!
+ other variables.
I figured this was normal! Is there a way to tell that both lift cylinders are functioning properly?
2017 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A67147)
2017 FREIGHTLINER...
2018 Tycrop Vector Belt VB-16H Sand Belt (A64194)
2018 Tycrop Vector...
John Deere AH202558 25ft Full Finger Auger (A65640)
John Deere...
78in Pro Tech HD Grapple (A65563)
78in Pro Tech HD...
2005 Lexus ES 330 Sedan (A64194)
2005 Lexus ES 330...
2007 PETERBILT 386 (A65643)
2007 PETERBILT 386...
