loader arms!
/ loader arms! #1
peter3759
Eden, NY
LS R4041H
When i detach my front end loader today to do some brush hogging i noticed that the cylinders on each side were moving at different rates! Is this because the hookups are on one side so that side gets better flow due to not having to lift the weight of the loader?
/ loader arms! #2
+ other variables.
when you actually have something attached to FEL (bucket, forks, etc..) the smaller differences dis-appear. and everything should move equally. more so when there is a load on the FEL.
/ loader arms! #3
It's completely normal for that to happen. Often there is a timing rod that runs between the two side to help keep them together, the JD's have small pins in these rods that are well known for breaking.
/ loader arms!
+ other variables.
I figured this was normal! Is there a way to tell that both lift cylinders are functioning properly?
New/Unused Landhonor Quick Attach Pallet Forks (A65583)
New/Unused...
2023 Kubota RTV-XG850 Sidekick (A66408)
2023 Kubota...
Caterpillar 446B Backhoe Loader (A66285)
Caterpillar 446B...
1995 Peterbilt 379 Tri-Axle Dump Truck (A61573)
1995 Peterbilt 379...
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
2005 LEDWELL LW40ADC - 40' ALUMINUM FEED TRAILER (A63290)
2005 LEDWELL...
