loader arms!
   / loader arms! #1
peter3759
Bronze Member
Eden, NY
LS R4041H
When i detach my front end loader today to do some brush hogging i noticed that the cylinders on each side were moving at different rates! Is this because the hookups are on one side so that side gets better flow due to not having to lift the weight of the loader?
   / loader arms! #2
+ other variables.
when you actually have something attached to FEL (bucket, forks, etc..) the smaller differences dis-appear. and everything should move equally. more so when there is a load on the FEL.
   / loader arms! #3
It's completely normal for that to happen. Often there is a timing rod that runs between the two side to help keep them together, the JD's have small pins in these rods that are well known for breaking.
   / loader arms!
+ other variables.
I figured this was normal! Is there a way to tell that both lift cylinders are functioning properly?
2020 KUBOTA RTV...
2005 KUBOTA L39 BACKHOE (A51242)
2005 KUBOTA L39...
2016 E35 Bobcat Mini Excavator (A50322)
2016 E35 Bobcat...
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52141)
2021 FREIGHTLINER...
2011 FREIGHTLINER M2 26FT BOX TRUCK (A50505)
2011 FREIGHTLINER...
Case 1150G Crawler Tractor Dozer (A50322)
Case 1150G Crawler...
