Backhoe Loader and backhoe for 3203:
/ Loader and backhoe for 3203: #21
Well JD4310man, if your mind is made up, then I guess it's made up. Nevertheless, you should still consider that the difference in features for the pricing difference:
Price difference: $1,650 list price
Item.................3203 ..........3120
Engine Displ ........91.5 ...........91.5
Torque:..............55.6 ...........55.6
RPM @ rated pwr......2800 ...........2600
RPM Range ...........950-2800 .......950-2810
Transmission ........2-Range ........3-Range
Rear Axle ...........4000lbs ........5292lbs
Rr Wheel Lugs ....... 6 .............8
Final Drive ......... Spur ...........Helical
Speedmatch .......... No .............Optional
Hydraulics PSI ...... 2150 ...........2500
GPM Total/Steer/Imp:. 13.3/5.7/7.6 ..13.9/5.3/8.6
Remotes Avail: ...... 2 .............5
3PH Lift at ends:.... 2149 ...........2530
mid PTO ............. NO .............Available
Power Beyond option.. NO .............Yes, $232 +/-
Oil Capacity .........4.5 ............5.1
ROPs conforms to: ....ASAE S478 ......ASAE, OSHA, SAE
ROPs type ............Fixed ..........Foldable
Operatator station....semi flat ......FLAT
Ship Weight ..........2700 ...........2900
Frankly, the difference is a little more than being just a "stripped down" version. Stipped down version suggests that it is the same less some options but this is not the case. The 3203 can never be reasonably modified to become a 3x20 series tractor. The transmission and axle are different. Since tractors aren't really mounted on a frame, the transmission and axle are an "integral" part of the chassis. For $1650 (before discount off list) less, you are going to get a 2 spd vs 3spd tranny, lighter duty rear axle, less robust hydraulics, fixed vs foldable rops, engine rated to produce 2.5hp (2pto) more but does so using same displacement motor running at higher rpm and compression with less crankcase fluid so the duty rating of the 3120 might be more durable in long run, no mid pto cap, 2 vs 5 available remotes, deere rated to use 300 vs 300x/300cx loader, deere rated to use no backhoe vs 447 and 448, final drive is spur vs a helical gear, 6 lugs vs heavier duty 8-lug axle. Finally, while the physical size does look to be about the same, there certainly are other design differences as well and even little things like the lights, perhaps you don't care about the aesthetics but functionally, are brighter on the 3x20 series. Again, the point is that for the price difference, you ARE giving up SOMETHING.
But again, if your mind is made up, then it's made up. Nothing wrong with the 3203 for what it is. All I'm saying is that if you want the 300x loader and backhoe cap, then why not pay the difference, small in the overall scheme of things when all costs have been factored in, to have the tractor that was designed with those in mind? Just my humble opinion, for whatever that is worth.
Superduper:
I really appreciate all of the information and your honest oppinions! I cant say that my mind is made up, im just looking at the machine that fits my needs as well as my pocket. Believe me if money wasnt an option I would definitly go for the 3520 with the 300cx loader and the 448 hoe! I will look at the 3120 closer and do some more compairing. Again thanks for all the input!!!
/ Loader and backhoe for 3203: #23
Do you already own the 4310? If so, why are you looking for a new machine?
I previously owned a 4310, But I had to sell it. Did not want to though, was a good machine!
1993 WhiteGMC WG Tri-Axle Dump Truck (A61573)
1993 WhiteGMC WG...
New/Unused Quick Attach Landhonor Hydraulic Winch (A65583)
New/Unused Quick...
2022 CATERPILLAR 289D3 SKID STEER (A65053)
2022 CATERPILLAR...
(INOP) 2018 FORD EXPLORER (A59823)
(INOP) 2018 FORD...
John Deere 670GP (A64126)
John Deere 670GP...
(2) 15X19.5 TIRES ONLY (A64281)
(2) 15X19.5 TIRES...
