Loaded tireson1502h
/ Loaded tireson1502h #1
jt41484
NISKAYUNA
iseki
Have a 1502h bolens and picked up a nail in the rear tire they are filled and was wondering how hard it is to repair
/ Loaded tireson1502h #2
Hi,
I think it really will depend on the depth of the nail, and what the tire is loaded with. If the nail penetrated the tire and tube, and the tire has calcium chloride in the tube, then that will be a concern because you do not want your rim to rust out from exposure. Worse case scenario, you can bring the tire on the rim to place loads tires, and have them drain, and save the fluid. You can then have a new tube installed, And the tire patched, and the should be able to reuse the old fluid. That would
most likely be the least expensive and best way to go unless you have the ability and equipment to remove a tire, and load a tire. I had to have this exact repair done on my Iseki G154 and it cost about $25. It really depends on where you bring it, and what they charge. Did the tire drain? Good luck with it, and let us know how it turns out!
Well i repaired it today wasnt as bad as i was expecting minus me breaking the nut holding the valve stem to the rim. Drained tire by having valve stem at bottom and hanging tire with forklift over a garbage can to drain into. Used tire machine to remove tire from rim and patched the tube.
Funny thing is i believe it was windshield washer fluid filled it was blue and smelled like it also
/ Loaded tireson1502h #5
Glad to hear that you have it fixed! My tires are actually loaded with windshield washer fluid. I only have my front tire loaded, and they have been for the life of the tractor to help provide ballast in the front in addition to the suitcase weights that I have mounted. The windshield washer fluid is incredibly less expensive than rim guard for me. There is huge debate on TBN over what to fill with, but for my uses, windshield washer works great because it weights the same as water, does not freeze, and costs pennies. I would prefer to have more ballast, but for the cost, this option works great. Do you have the adapter to re-load your tires? Glad to hear that you have it back up and running! Happy New Year..
/ Loaded tireson1502h #6
What is an adapter to reload the tires?, I need one, is there a formal name so I can search for it?
I got one at napa told them it was to fill tires with calcium
ALLMAND MP65-8E1 PORTABLE (3) PHASE GENERATOR (A63276)
ALLMAND MP65-8E1...
IRMC High-End Massage Chair (A64047)
IRMC High-End...
2010 Ford Crown Victoria Sedan (A61574)
2010 Ford Crown...
2019 PETERBILT PB337 LUBE TRUCK (A63276)
2019 PETERBILT...
2018 KEARNEY TRAILER 24 FT GOOSENECK TRI-AXLE (A63569)
2018 KEARNEY...
2020 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A61568)
2020 Chevrolet...
