Tires Loaded tires? How do you tell?
   / Loaded tires? How do you tell? #21
Dargo said:
Speaking of loaded tires, what air pressure do you generally run in tires if they are loaded? The normal pressure?
I use the maximum that is posted on the side of the tire sidewall. If you let the air pressure drop in a loaded tire, you run the chance of having the tire break off the seated bead and loosing all its liquid and going flat.
Dusty
   / Loaded tires? How do you tell? #22
I do like Dusty, run max pressure in them and maybe even a little over max. There is still plenty of "give" in the tires even at max pressure.
2008 New Holland B110 MFWD Loader Backhoe (A57024)
2008 New Holland...
2018 Ford F350 (A55973)
2018 Ford F350...
2021 CAT 304E2 (A53317)
2021 CAT 304E2...
2018 John Deere 30G Mini Excavator (A56857)
2018 John Deere...
2013 Ford F250 (A55973)
2013 Ford F250...
2010 Ford F150 Single Cab Pickup Truck (A55973)
2010 Ford F150...
