Tires Loaded tires? How do you tell?
   / Loaded tires? How do you tell? #21
Dargo said:
Speaking of loaded tires, what air pressure do you generally run in tires if they are loaded? The normal pressure?
I use the maximum that is posted on the side of the tire sidewall. If you let the air pressure drop in a loaded tire, you run the chance of having the tire break off the seated bead and loosing all its liquid and going flat.
Dusty
   / Loaded tires? How do you tell? #22
I do like Dusty, run max pressure in them and maybe even a little over max. There is still plenty of "give" in the tires even at max pressure.
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A56435)
Neckover GL24-2-7K...
2019 KENWORTH T800 HOTOILER (A58214)
2019 KENWORTH T800...
PALLET OF 15 4 X 8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4 X 8...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
Cushman Electric Cart (A55853)
Cushman Electric...
LINCOLN ELECTRIC RANGER 225 GAS WELDER/GENERATOR (A54757)
LINCOLN ELECTRIC...
