Loaded for bear
/ Loaded for bear #31
Automotive air conditioning pumps make great compressors. Could make a PTO driven contraption, or, could build brackets to mount it on the engine and drive from the fan belt. This is a VERY popular thing with 4-wheelers. A lot of hard rock rigs will air down to 2-6psi, and then need to fill back up beforee they hit the pavement.
My Brother in law put one on his Jeep. He airs up 26x16.5 tires pretty quickly.
RobertN in Shingle Springs Calif
/ Loaded for bear #32
I have tried this before transfering used oil from drums to oil tank. Usually ended up with a mess. But I think the diesel fuel should flow easier. I might give it a try. I'll let you know. Will be a while gotta get the service trucks ready for winter along with other out door stuff. Thanks for the info!
Derek
/ Loaded for bear #33
Harv
Sounds like you have almost everything, how about insurance?
Your homeowners insurance may not cover your tractor since it is off the lot your house sets on. I also found out if you do have it covered for the land it is on, if you drive off the land, it may not be covered. If you haul it it mau not be covered. Just some things to check
Dan L
2024 CATERPILLAR 305 CR EXCAVATOR (A52709)
2024 CATERPILLAR...
2009 Kubota RTV1140 (A57148)
2009 Kubota...
2024 Linx EQ07018RS (A60463)
2024 Linx...
(15) Polyethylene Road Bed Protection Pads (A60463)
(15) Polyethylene...
2006 Keystone Laredo 29RL 31ft. T/A 5th Wheel Travel Trailer (A55853)
2006 Keystone...
2018 Multiquip AR-14 (A60462)
2018 Multiquip...
