Loader LL 3601 loader
/ LL 3601 loader #1
steveG3038
LS G3038
Just checking to see if anyone knows where a person could get rebuild parts for the hydraulic cylinders. The company that made the LL 3601 loader that came with my G3038 is out of business and no parts are available. Sad since this is a 2013 model tractor.
/ LL 3601 loader #2
Most of the time, you will be money ahead just by taking the cylinders to a reputable shop and have them rebuilt.
If you could find a kit for your cylinders, it will probably cost you $200 by the time you get the parts. A good shop will have a huge supply of seals and packings that they get for a couple bucks. And if they find anything damaged once they open them up, they can easily fix or replace any needed parts.
/ LL 3601 loader #3
Great suggestion 3Lfarms, that is the best thing to do and should not be hard to find a reputable repair shop to do this repair.
/ LL 3601 loader
Thank you, I will look into a shop near me.
/ LL 3601 loader #6
Probably a few years late to the game. BUT I did find a great lift cylinder replacement for my 3038 from princess auto (canada) only cost me 110 dollars. You’ll need to turn it the opposite way, and get longer hoses (since you need to switch the plumbing around a bit, but it’s been working great for 2 years. The SKU number has since worn off the cylinder but if you do a search on Google, you will find the extended/retracted dimension measurements of your current loaders cylinder . From there you just need to get one that’s close. Attached a couple pics to help further my explanation..Hope this helps
New/Unused Landhonor Hydraulic Quick Attach Auger (A65583)
New/Unused...
2005 DRAGON END DUMP TRAILER (A65643)
2005 DRAGON END...
25' Flat Fold Cultivator (A66408)
25' Flat Fold...
Drag Tank, Fill Rite 15GPM PUMP  (A62679)
Drag Tank, Fill...
2015 INTERNATIONAL PROSTAR 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2015 INTERNATIONAL...
John Deere 700 H Dozer (A62679)
John Deere 700 H...
