lk3054 shifter stopped working
/ lk3054 shifter stopped working #1
66gt350
Redding, CA
Kioti LK3054
Over the weekend, the shifter on my 3054 decided to stop working. It's stuck in I believe second gear. The shifter does nothing, it's just free floating. It pulls up about 6 inches, and I can see what looks like a bolt that has sheared off. I just ordered a parts manual and service manual, but they won't be in for a week. I started to take off the cast iron plate that's on the side of the tranny, to get a look to see what's the problem, but have run into trouble. I took out all the bolts, but the plate is stuck on there. It looks like there's a sealant holding it on. Does this come off easy or will this take major surgery to fix? Does someone have a scanned copy of the parts blow up of the tranny and shifter area, so I can work on this while mine are being shipped?
edit: I went to the local dealer, which they've only been a dealer about a week, and got a blow up of the area I need. It looks like the main shift cover should come straight off. It must be held on by some sealant from hades. I guess that I'll just have to work on breaking the sealant free. Any words of wisdom?
thanks
/ lk3054 shifter stopped working #3
I believe there is a roll pin that you probably broke or came loose and that is what has your shifter lever free, seems like a common issue, but simple to fix.
Joel
/ lk3054 shifter stopped working #4
thanks
I have the same issue. Could you please explain the repair and if you were able to fix. Thank you
/ lk3054 shifter stopped working #5
I realize that you’re a new member…welcome. But this thread is from two thousand and ten so the OP may not reply. Respond with tractor model, current hours and symptoms. Hopefully someone with a similar experience can provide some insight/help for you …😉
/ lk3054 shifter stopped working #6
Hi guys,
I’ve not personally had to fix but seen similar posts.
I can provide pics of repair manual if you don’t already have
/ lk3054 shifter stopped working #7
Hi guys,
JoelD that would be very helpful. I’m reviewing the parts manual and checking out the parts that interfere. Getting ready to drain the hydraulic fluid. Thank you.
/ lk3054 shifter stopped working #8
Thread '2006 Lk3054xs, 573 hours, loose shifter. Stuck in fourth gear.'
I refreshed my request per Robin’s recommendation. If you could reply there with any advice I would appreciate it. Thanks again for responding to the post.
2024 CATERPILLAR 306CR EXCAVATOR (A60429)
2024 CATERPILLAR...
Dayton 32965 80-Gallon Horizontal Air Compressor, 22 Volts, 5 HP, 2 Stage, 3 Phase (A59076)
Dayton 32965...
BUNDLE OF 8'-13' CORRUGATED METAL SHEETS (A60432)
BUNDLE OF 8'-13'...
Brush Cutter Mini Skid Steer Attachment (A59228)
Brush Cutter Mini...
Box of Transport Ratchet Straps (A59230)
Box of Transport...
2009 MULTIQUIP 25KW GENERATOR (A58214)
2009 MULTIQUIP...
